Hi.
I have 2 expressions, the first expression cosist of x´s and y´s, the other expression consits only of x´s
I wanna test the relation between those 2 expression to check wether A>B giving the condition that 2y<x
I have tried this:
assume(2y<x);
is(A>B);
the problem is that maple returns FAIL, I could put in values to check and it works, but that is not really what im trying to acomplish.
Please help me to solve the system of 1st order singular O.D.E  (see uploaded file)....New_Microsoft_Office_Word_Document.docx
Hi Maple Primes,
Can this code be improved?
I know that the Goldbach Conjecture has been checked with computer tools above 10^10.
Request for comments.
check_g_conjecture_26_b.mw
check_g_conjecture_26_b.pdf
Matt
I am working on a Dirichlet breakdown of primes. I need a way to check if a number is part of anothers number factorization.
Example: 30 = 2*3*5.
2 is therefore part of the ifactor of 30. 4 and 7 are not.
How do I check if, for instance, 7 is part of de factorization of 390?
I tried to define the Poisson bracket in this way
Ps:=proc(f,g)
local P;
P:=simplify(diff(f,P[1])*diff(g,X)-diff(f,X)*diff(g,P[1])+
diff(f,P[2])*diff(g,Y)-diff(f,Y)*diff(g,P[2]));
end;
The problem is that, if I ask Ps(P[1],X) I got 0 which is clearly wrong.
Where is the error?
https://dl.dropboxusercontent.com/u/51122291/Scrreshot.jpeg
Thanks Nicola
sol_L := dsolve({de_L, ic});
    {x(t) = (-y0 - x0) exp(-2 t) + (y0 + 2 x0) exp(-t),
      y(t) = -2 (-y0 - x0) exp(-2 t) - (y0 + 2 x0) exp(-t)}
How i can plot this?thanks
Hi everybody;
I have a problem with Physics[diff] command. When I run the following code, error messages appear where the Physics[diff] command exist. What is the source of error? How can I fix it?
Q1.mw
In response to Markiyan Hirnyks reference to Mathematica's FindDistribution command http://www.mapleprimes.com/questions/219668-Determine-The-Distribution-Function.  It would be nice to have something similar coded in Maple.
Hello.
I am taking an intermediate mathematics course. Now we are heading towards the finals and I have started to review all the topics we have been visiting during this semester.
Now I came across an excercise I cannot solve, taking into consideration what our lectures looks like and topics on the list my best bet is using lagrange multiplie method to optimize a multivariable function with constraints.
The task gives a shape that is drawn within the circle given by the equation: x^2+y^2=2.
The shape is a hexagon with 2 vertecies on the y-axsis +- the radius 2, the other 4 vertecies are the following [+-x,+-y].
I´m told that this hexagon is spinned around the y-axis to form a solid sylinder with 2 cones. The problem is to choose both radius and hight of the cylinder in order to maximize the volume.
The first problem that I dont know how i can plot this in maple, I would like to plot both the 2d hexagon and the solid spinned around the y-axsis
Also I´m not to confident what the constraint should look like.
I know how to use the lagrange multiplier by hand and can apply that inside maple, however I would like to use this opportunity to get to know the power of maple functionality more in detail.
https://i.gyazo.com/9d9585ddb8eb719d2a5bd24a1ba1671b.png
The link provoided is an image of the hexagon, i didnt find out how to use image tags.
how to configure maple to show every steps it run when solve a equation or system?
if so,
can i run the steps again and return the same result as a solve function do?
solve Derivative in maple
see in photo
I want to generate a table in maple, but with generic content. For example, in Mathematica you can do this using
table=Table[0,{n=10},{m=2}];
and this generates a table with 2 columns and 10 rows with zeros in all its elements. I want to do this exactly but in maple.
Thanks for your time!
O(t) = 9.2-[(8.93*35.3)/(11.17-8.93)]*(exp(-8.93*t)-exp(-11.17*t))-8.3*exp(-11.17*t)
t betwen 0 and 1
I'd like to bring up all the Maple 2016 applications from the application center.
How do I do that?
I would like to ask you to help me with the following problem that I got error.
restart; Shootlib := "C:/Shoot9"; libname := Shootlib, libname; with(Shoot);
N1 := 1; N3 := .5; N2 := 5; Bt := 6; AA := N1*Bt; gamma1 := .2; blt1 := 1;
FNS := {f(eta), fp(eta), fpp(eta), g(eta), gp(eta), h(eta), hp(eta), i(eta), ip(eta), fppp(eta)};
ODE := {diff(f(eta), eta) = fp(eta), diff(fp(eta), eta) = fpp(eta), diff(fpp(eta), eta) = fppp(eta), diff(g(eta), eta) = gp(eta), diff(gp(eta), eta) = N1*(2*g(eta)+eta*gp(eta)+2*g(eta)*fp(eta)-2*f(eta)*gp(eta)+2*N2*N3*(h(eta)*ip(eta)-i(eta)*hp(eta))), diff(h(eta), eta) = hp(eta), diff(hp(eta), eta) = AA*(h(eta)+eta*hp(eta)-2*f(eta)*hp(eta)+2*h(eta)*fp(eta)), diff(i(eta), eta) = ip(eta), diff(ip(eta), eta) = AA*(2*i(eta)+eta*ip(eta)-2*f(eta)*ip(eta)+2*N2*h(eta)*gp(eta)/N3), diff(fppp(eta), eta) = N1*(3*fpp(eta)+(eta-2*f(eta))*fppp(eta)-(2*N2*N2)*(diff(hp(eta), eta)))};
IC := {f(0) = 0, fp(0) = gamma1*fpp(0), g(0) = 1+gamma1*gp(0), gp(0) = beta, h(0) = 0, hp(0) = beta1, i(0) = 0, ip(0) = beta2, fppp(0) = alpha};
BC1 := {f(blt1) = .5, fp(blt1) = gamma1*fpp(blt1), g(blt1) = gamma1*gp(blt1), h(blt1) = 1, i(blt1) = 1};
infolevel[shoot] := 1;
S := shoot(ODE, IC, BC1, FNS, [alpha = .1, beta = .2, beta1 = .3, beta2 = .4], maxfun = 50000);
First 1089 1090 1091 1092 1093 1094 1095 Last Page 1091 of 2464
