I have downloaded and trying to run the application "Traveling Salesman Problem" by Bruno Guerrieri:
http://www.maplesoft.com/applications/view.aspx?SID=6873
However, the animations do not work properly. Instead of the animations, I get series of sets of plots. Each such set consists of four plots: one with a green edge, one with a blue edge, one with blue edges, and one with points (nodes).
I guess, it happens because of a new version of maple: the application was created in 2008 for Maple 12, and I use Maple 2015.
Could anybody, please, tell me what exactly should I change in the code so that it will work properly?
Any help will be very much appreciated.
Many thanks in advance!
Hi All,
I'm trying to numerically solve a differential equation which has a numeric function in it.
For example, consider the function f.
f:=(r)-> evalf(Int( <some messy function>, <some range>)) ;  <- This can be solved numerically and returns an answer quickly. i.e
f(23) gives 102;
Now, I want to numericaly solve something like.
Eq:= diff(p(r),r,r) + diff(p(r),r) - f(p(r));
ICS:=D(p)(0.001)=0, p(0.001) = 3
dsolve({Eq,ICS},numeric).
dsolve will not attempt to solve it due to the numeric integration in f. Is there a way I can just use numeric techniques to solve this kind of problem?
Is it possible to view maple workbook content in older versions?
This is for the infamous Calc 2 Goblet Maple Project
I have tried everything changed all the numbers and got nowhere or worse results. The only thing that accurately works is the example project:
(0, 1.5) and end at (0.5, 0.2). which equals f1(x)=-2.6x+1.5
and f2:=x->0.2+0.05*sin(2*(x-0.5)) which is really 0.2+0.05sin(2x-1)
The goal is to change the example project so it becomes something of my own creation.
When I change f2:=x->0.4+0.05*sin(2*x-0.5)) it is at least attached but forms a sharp dip down first then connects at the point when it should be smooth curve. It seems you can do anything to the other curve
f3:=x->a*x^3+b*x^2+c*x+d;
x -> a x^3 + b x^2 + c x + d
connection1:=f3(5.5)=f2(5.5);
166.375 a + 30.25 b + 5.5 c + d = 0.3727989445
arc1:=f3(7)=1;
343 a + 49 b + 7 c + d = 1
arc2:=f3(7.5)=0.9;
421.875 a + 56.25 b + 7.5 c + d = 0.9
arc3:=f3(9)=1.6;
729 a + 81 b + 9 c + d = 1.6
values:=solve({eq1,eq2,eq3,eq4},{a,b,c,d});
F:=x->piecewise(x<0.5,f1(x),x>=0.5 and x<5.5,f2(x),x>=5.5,f3(x));
plot(F(x),x=0..9,y=0..4,scaling=constrained);
So how can this be fixed?
I have an equation
eq := diff(y(x), x) = ((76.559-179.54*((1/3600)*x+1)+113.15*((1/3600)*x+1)^2-13.661*((1/3600)*x+1)^3+.4621*((1/3600)*x+1)^4)*.88-.15*((76.559-179.54*((1/3600)*x+1)+113.15*((1/3600)*x+1)^2-13.661*((1/3600)*x+1)^3+.4621*((1/3600)*x+1)^4)*.88)*(1-0.45e-2*(y(x)-9.8-273))-(3.8+2.8*3.7+5.76*10^(-8)*(y(x)^2+(273+9.8+(1/46800)*(18.3-9.8)*x)^2)*(y(x)+273+9.8+(1/46800)*(18.3-9.8)*x))*(273+9.8+(1/46800)*(18.3-9.8)*x-y(x)))/(903*(2702*0.2e-2));
Maple gives me a general solution.
then I  tried to get a particular solution using dsolve({eq, y(0) = 283.8});
But Maple dose not return anything.
Thank you for any help.
Is there a difference between these two?
with(Statistics):
Sample(Normal(0,1),100)
Sample(RandomVariable(Normal(0, 1)), 100)
I am trying to solve numerically int( f(t,z) , t=0..T ) = 0 , in z for a cumbersome f.
I tried z1=fsolve( int( f(t,z) , t=0..T ) = 0 , z). But then I tried int( f(t,z1) , t=0..T ) and the result is clearly not zero nor anything small.
It looks like Maple evaluates analytically the integral, and does it wrong (check this for more details) so fsolve uses the wrong equations.
Anyone knows how I can force Maple to evaluate numerically the integral at each step of the fsolve function?
In the creation of package wrapping some procedures, may you tell me the differences between using a table or a module so as to wrap the procedures ?
In my case, it seems to me that table is more convenient since I can create with table packages while keeping my program with a structure of section, subsection, ...
But, I'm a beginner in the use of packages. Consequently, I'm very interested in your opinions on this question.
Thanks a lot for your help
hi,i am studying the maple most recent.But when calculating function integral,I ran into trouble.I hope to get your help.Here is the code I wrote, but it runs a very long time. How to effectively reduce the integration time?
with(student);
assume(n::integer);
Fourierf := proc (sigma, a, b, N) local A, A0, B, T, S, Ff; T := b-a; A0 := int(sigma, t = a .. b); A := int(sigma*sin(n*Pi*t/T), t = a .. b); B := int(sigma*cos(n*Pi*t/T), t = a .. b); S := sum(A*sin(n*Pi*t/T)+B*cos(n*Pi*t/T), n = 1 .. N)+(1/2)*A0; Ff := unapply(S, t) end proc;
f := proc (t) options operator, arrow; piecewise(t < .13*2.6 and 0 <= t, 100*t/(.13*2.6), .13*2.6 <= t and t < 2.6, 100, 2.6 <= t and t < 2.6*1.1, 0) end proc;
sigma := f(t);
a := 0;
b := 1.1*2.6;
s1 := unapply((Fourierf(sigma, a, b, 500))(t)/uw0, t);
s2 := unapply((Fourierf(sigma, a, b, 500))(t)/ua0, t);
A1 := (2*n+1)^2*Pi^2*(C3+1+sqrt(4*C1*C2*C3+C3^2-2*C3+1))/(8*C1*C2-8);
A2 := (2*n+1)^2*Pi^2*(C3+1-sqrt(4*C1*C2*C3+C3^2-2*C3+1))/(8*C1*C2-8);
g := -C2*Cww*(diff(s1(x), `$`(x, 2)))+Caa*(diff(s2(x), `$`(x, 2))+(n+1/2)^2*Pi^2*(diff(s2(x), x)));
f1 := -(1/2)*(n+1/2)^2*Pi^2*sqrt(4*C1*C2*C3+C3^2-2*C3+1)+C2*Cww*((D@@1)(s1))(0)-Caa*((D@@1)(s2))(0)+(n+1/2)^2*Pi^2*(C2-(1/2)*C3+1/2);
CN := ((2*(int(exp(-A1*x)*g, x = 0 .. t)-f1))*exp(A1*t)-(2*(int(exp(-A2*x)*g, x = 0 .. t)-f1))*exp(A2*t))/((n+1/2)^3*Pi^3*sqrt(4*C1*C2*C3+C3^2-2*C3+1));
ua := sum(CN*sin((n+1/2)*Pi*z), n = 0 .. 100);
I want to solve one equation with one variable and the variable is also in definite integral delimiter. When trying fsolve, I get the error:
"Error, (in fsolve) Can't handle expressions with typed procedures"
code
Here is worksheet.mw
How can I obtain solution with method other from simple manual testing Te values?
Dear All
I have started exploring Lie Algebra package in Maple 18 and it wonderful experience for me. But as I am in learning stage so I feel little difficulty to understand even its basic enviroment.
I am trying to fing quotient algebra for Normalizer of certain element W1 in Lie algebra and I don't how to do it. I have expected answer for quotient of Normlizer but don't know to obtain it. Please see following details:
with(DifferentialGeometry):with(LieAlgebras):``
L1 := _DG([["LieAlgebra", Alg1, [6]], [[[1, 3, 1], -1], [[1, 6, 2], -1], [[2, 3, 2], -1], [[2, 4, 1], 1], [[2, 5, 2], 1], [[4, 5, 4], -1], [[4, 6, 3], -1], [[4, 6, 5], -2], [[5, 6, 6], -1]]])
DGsetup(L1)
`Lie algebra: Alg1`
Alg1 >
MultiplicationTable("LieTable")
"[[[,`| `,e1,e2,e3,e4,e5,e6],[,-`---`,-`---`,-`---`,-`---`,-`---`,-`---`,-`---`],[e1,`| `,0,0,_DG([["vector",Alg1,[]],[[[1],-1]]]),0,0,_DG([["vector",Alg1,[]],[[[2],-1]]])],[e2,`| `,0,0,_DG([["vector",Alg1,[]],[[[2],-1]]]),_DG([["vector",Alg1,[]],[[[1],1]]]),_DG([["vector",Alg1,[]],[[[2],1]]]),0],[e3,`| `,_DG([["vector",Alg1,[]],[[[1],1]]]),_DG([["vector",Alg1,[]],[[[2],1]]]),0,0,0,0],[e4,`| `,0,_DG([["vector",Alg1,[]],[[[1],-1]]]),0,0,_DG([["vector",Alg1,[]],[[[4],-1]]]),_DG([["vector",Alg1,[]],[[[3],-1],[[5],-2]]])],[e5,`| `,0,_DG([["vector",Alg1,[]],[[[2],-1]]]),0,_DG([["vector",Alg1,[]],[[[4],1]]]),0,_DG([["vector",Alg1,[]],[[[6],-1]]])],[e6,`| `,_DG([["vector",Alg1,[]],[[[2],1]]]),0,0,_DG([["vector",Alg1,[]],[[[3],1],[[5],2]]]),_DG([["vector",Alg1,[]],[[[6],1]]]),0]]]"
Alg1 >
W1 := [a*e3+e5]
[a*_DG([["vector", Alg1, []], [[[3], 1]]])+_DG([["vector", Alg1, []], [[[5], 1]]])]
Alg1 >
Nor[W1] := SubalgebraNormalizer(W1)
[_DG([["vector", Alg1, []], [[[5], 1]]]), _DG([["vector", Alg1, []], [[[3], 1]]])]
How one can find Quotient alegebra "(Nor[W1])/(W1)....???`? ``The expected answer is {e3}.`"
I am trying verify 4th 2-dimensional subalgebra results given in research artcle by Coggeshall and Meyer-ter-Vehn (See pp. 3592 in article).
Download [670]_Normalizer_in_Abstract_Lie_Algebra.mw
I have tried to perform the examples given in the help section for DataSet retrival.  I cannot get Maple 2016 to access the internet available databases.  It does not return any outside of PC resources, like Maple 2015 did, on search items. Is there a setup item that I am missing or is there something amiss in Maple 2016.
This is the Error that I am getting: "Error, (in DataSets:-Search) invalid input: find_count expects its 1st argument, lst, to be of type list(nonnegint), but received [FAIL["total_count"], 0]. "
I was able to run this example in Maple 2105.  The example is the "Average Global Temperature"
Bill Tolrud
I need to do this with a sequence of a large number of elements but here is my question with a sequence of fewer elements.
a:={10,11,-13,9,20,74,10}:
I want to check each element of the sequence if it is negative. And if any element is negative I want to replace with 0 (or do something else). I tried the following code but it didn't work.
for k from 1 to 7 do
  if (a[k]<0) then subs(a[k]=0, a) end if:
Please help me to figure it out.
@ecterrab
hello dear,
was working with tensor package using debever formalism in maple v release 5 and got this problem,
Error, (in factor) expecting a polynomial over an algebraic number field. would u tell me how to deal with this error in maple v release 5. aprl12.mws
thanks,
suresh
can you please help me with the usage of applyrule? I have the following problem that I cannot isolate. I have a rule that I want to apply, but instead of applying the rule to the expression, the rule seems to be applied to itself. In an isolated worksheet everything is fine:
rule:=abs(''a''::algebraic)^2=''a''^2;
abs('a'::algebraic)^2 = 'a'^2
myexp:=abs(548.477146186283171377723+radius_motor*q_mot_vec_2(t)-l_wire_0[2])^2
applyrule(rule,myexp);
rule
abs(a::algebraic)^2 = a^2
Download applyrule.mw
What happens when I try to use this rule in my script is this:
#read "some_long_script.mpl":
applyrule(rule,abs(x)^2)
abs(x)^2
rule
a::algebraic^2 = a^2
I want to clarify, that the script that is read before applying those rules does not apply a similar rule. Also the variables rule and x were free. Can you please help me to locate the problem?
Honigmelone
First 1141 1142 1143 1144 1145 1146 1147 Last Page 1143 of 2434
