Does `evala/toprof` still exist in newer Maple versions, or is there an equivalent?
Why won't this procedure Compile? All I get is a cryptic and ungrammatical error message.
    step:= proc(
          n::integer[4],
          XYZ::Matrix(datatype= float[8]),
          E::Vector(datatype=integer[4]), F::Vector(datatype=integer[4]),
          W::Matrix(datatype= float[8]), #3x2 scratch matrix
          mu::integer[4]
     option autocompile;
     local
          i::integer[4], j::integer[4],
          ed::float[8],
          fd::float[8],
          p::float[8], t::float[8]
          to mu do
               for i to n do
                    ed:= 0;  fd:= 0;
                    for j to 3 do
                          p:= XYZ[i,j];
                          t:= XYZ[E[i],j] - p;
                          ed:= ed+t^2;
                          W[j,1]:= t;
                          t:= XYZ[F[i],j] - p;
                          fd:= fd+t^2;
                          W[j,2]:= t
                    od;
                    ed:= sqrt(ed) + .01;  fd:= sqrt(fd) + .01;
                    for j to 3 do
                         XYZ[i,j]:= 0.995*XYZ[i,j] - 0.01*W[j,1]/ed + 0.02*W[j,2]/fd
                    od
               od
          od
Compiler:-Compile(step);
Error, (in Compiler:-Compile1) In memory compilation failed
I have somme difficulties to calculate this integral.
int(I*sqrt((R*exp(I*theta)+1)/(R*exp(I*theta)-a)), theta = 0 .. Pi);
Hello guys,
I was just playing around with differential equations, when I noticed that symbolic solution is  different from the numerical.What is the reason for this strange behavior?
ODE := (diff(y(x), x))*(ln(y(x))+x) = 1
sol := dsolve({ODE, y(1) = 1}, y(x))
a := plot(op(2, sol), x = .75 .. 2, color = "Red");
sol2 := dsolve([ODE, y(1) = 1], numeric, range = .75 .. 2);
b := odeplot(sol2, .75 .. 2, thickness = 4);
display({a, b});
Strange_issue.mw
Mariusz Iwaniuk
I need to crate a function to be evaluated in a range of values, and this function i would to use in other expression, example:
cel1      "seq(i,i=0.001..2,0.001)"
cel2      "A:=&1";cel1
cel3      "f:=x->diff(KelvinBei(0,x),x)"
cel4      ""B:=map(x->f(x),[A])"
This is ok with a lot of function but with diff(KelvinBei(0,x),x) in cel4 show this error "Error,(in f) invalid input:.1e-2, which is not valid for its 2nd argument.
Why??? How can I do??
Hello guys,
I was just playing around with the Shanks transformation of a power series, when I noticed that polynomials aren't evaluated as I would expect.
I created this minimal working example; the function s should evaluate for z=0 to a[0], however it return simply 0.
Is there something I messed up?
s := proc (n, z) options operator, arrow; sum(a[k]*z^k, k = 0 .. n) end proc;
series(s(n, z), z = 0)
series(a[0]+a[1]*z+a[2]*z^2+a[3]*z^3+a[4]*z^4+a[5]*z^5+O(z^6),z,6)
The value of s in z=0 should be a[0], however it returns 0:
s(n, 0)
s(1, 0)
Download evaluate_sum.mw
Thanks for your help,
Sören
It is believeble for me that the KummerU function is infinite or has a singular solution at r=0;
but without the command D(R) and dsolve ({er, D(R)(0)=0}, {R(r)}) that show the r=0 is a singular solution for the R(r), how could I prove it without using of these commands: for example is plotting of this function applicable??
while we have not the value of the  \lambda
eq := diff(R(r), r, r)+(diff(R(r), r))/r+(-r^2+1)*lambda^2*R(r) = 0;
diff(diff(R(r), r), r)+(diff(R(r), r))/r+(-r^2+1)*lambda^2*R(r) = 0
dsolve(eq);
R(r) = _C1*exp(-(1/2)*lambda*r^2)*KummerM(1/2-(1/4)*lambda, 1, lambda*r^2)+_C2*exp(-(1/2)*lambda*r^2)*KummerU(1/2-(1/4)*lambda, 1, lambda*r^2)
dsolve({eq, (D(R))(0) = 0}, {R(r)})
R := proc (r) options operator, arrow; C1*exp(-(1/2)*lambda*r^2)*KummerM(1/2-(1/4)*lambda, 1, lambda*r^2)+_C2*exp(-(1/2)*lambda*r^2)*KummerU(1/2-(1/4)*lambda, 1, lambda*r^2) end proc
D(R)
proc (r) options operator, arrow; -C1*lambda*r*exp(-(1/2)*lambda*r^2)*KummerM(1/2-(1/4)*lambda, 1, lambda*r^2)+2*C1*exp(-(1/2)*lambda*r^2)*((lambda*r^2-1/2-(1/4)*lambda)*KummerM(1/2-(1/4)*lambda, 1, lambda*r^2)+(1/2+(1/4)*lambda)*KummerM(-1/2-(1/4)*lambda, 1, lambda*r^2))/r-_C2*lambda*r*exp(-(1/2)*lambda*r^2)*KummerU(1/2-(1/4)*lambda, 1, lambda*r^2)+2*_C2*exp(-(1/2)*lambda*r^2)*((lambda*r^2-1/2-(1/4)*lambda)*KummerU(1/2-(1/4)*lambda, 1, lambda*r^2)-KummerU(-1/2-(1/4)*lambda, 1, lambda*r^2))/r end proc
Download Kummer.mwKummer.mw
I am generating a sphere with increasing radius that interacts at some point with a plan, just like this:
I would like to find a way to make the sphere "wave" (I agree this is not a wave...) reflected by the plan as in a mirror.
How could I do that ?
Thanks a lot for your help.
B
Im trying to draw a shpere but it always saying:
Error, (in plot3d) unexpected option: z = -2 .. 2
this is the equation: x^2+y^2+z^2-4=0
i'm writing this way
plot3d(x^2+y^2+z^2-2^2, x = -2 .. 2, y = -2 .. 2, z = -2 .. 2)
what should I do? this is my first time with this software
best from Brazil,
Nina
Greetings to all.
With the following matter I am betting on there being a simple mistake on my part due to fatigue owing to a challenging session of intense computing. The following link at Math.Stackexchange.Com points to a computation involving complex residues. Consult the link for additional details.
I usually verify my computations with Maple, I did the same this time. Thereby I happened on a curious phenomenon which I have documented below. Please study the session data provided, I believe it speaks for itself.
user@host:~$ math
Mathematica 10.0 for Linux x86 (64-bit)
Copyright 1988-2014 Wolfram Research, Inc.
In[1]:= Residue[z^2/(z^4 + 2*z^2 + 2)^2, {z, 2^(1/4)*Exp[3*Pi*I/8]}]
            1/8      1/4
        (-1)    ((-1)    + Sqrt[2])
Out[1]= ----------------------------
            1/4      1/4           3
        16 2    ((-1)    - Sqrt[2])
In[2]:= N[%]
Out[2]= 0.117223 - 0.0083308 I
In[3]:=
user@host:~$ maple
    |\^/|     Maple 18 (X86 64 LINUX)
._|\|   |/|_. Copyright (c) Maplesoft, a division of Waterloo Maple Inc. 2014
 \  MAPLE  /  All rights reserved. Maple is a trademark of
 <____ ____>  Waterloo Maple Inc.
      |       Type ? for help.
> residue(z^2/(z^4 + 2*z^2 + 2)^2, z=2^(1/4)*exp(3*Pi*I/8));
> quit
memory used=0.9MB, alloc=8.3MB, time=0.07
user@host:~$
I am looking forward to learning what the correct syntax is to get the residue in this case and I hope I can assist other users who might have run into the same problem. I will cancel the question should it turn out to be trivial and of little potential use to the community.
Best regards,
Marko Riedel
Post Scriptum. Being a programmer myself I would be curious to learn more about the algorithms that are deployed here and how and why they did not succeed.
Please check this:
N:=3;
sum1 := lcm(N, 0)+lcm(N, 1)+lcm(N, 2)+lcm(N, 3);
sum2 := sum(lcm(N, k), k = 0 .. N);
Why is sum2 wrong?
César Lozada
hi.
how i can solve two equation with respect to parameter sigma1
SOLL.mw
restart; pprime11 := -16395.36603*q1+5.811117425*q1*sigma1^2+3526.724044*p1-1.250000000*p1*sigma1^2+4.999870968*10^11*p1^3+4.999870970*10^11*p1*q1^2+7.967307034*10^14*p1^2*q1+4.999870966*10^12*sigma1*p1^2*q1-2.655769012*10^14*q1^3+4.999870968*10^12*sigma1*q1^3-17633.62022*q1*sigma1+6.250000000*q1*sigma1^3
qprime11 := 2.655769012*10^14*p1^3-7.967307034*10^14*p1*q1^2+4.999870970*10^11*p1^2*q1-4.999870968*10^12*sigma1*p1^3-4.999870966*10^12*p1*sigma1*q1^2+3526.724044*q1-1.250000000*q1*sigma1^2+16395.36603*p1-5.811117425*p1*sigma1^2+4.999870968*10^11*q1^3+17633.62022*p1*sigma1-6.250000000*p1*sigma1^3:
-50 < sigma1 and sigma1 < 50:
sigma1 <> 53.11665685, -53.11665685:
SOLL := solve({pprime11, qprime11}, real)
Download SOLL.mw
Is it possible, and how, to disable the automatic completion in the "Advanced Search / keyword" field ?
Underlying this question is my looking for informations about cmaple (beyond what the help page displays : if I can't find any I will ask some specific ones later). But every time I type "cmaple" in the keyword textfield, it is replaced by "campée" (which is a french word ... I guess english people will obtain something different)
does anyone know a way to combine two plots in one where one is created with ScatterPlot3D (Package:Statistics) and the other one with plot3D (Package:plots)?
Normally you would write something like this:
but that only works if the plots are from the same package...
The first example is very slow compared to the second.  The difference is in the definition of f().
y := int(1/(-0.4016e-1*m^(2/3)-0.211e-3*m^(5/3)), m);
f:= unapply(abs(y), m):
n := 500: ## sample size
M := <seq(2*idx/n,idx=1..n)>; ## m
Y := f~(M)+~Statistics:-Sample(Normal(0,3), n)^+; ## signal + noise
f:= (x) -> abs(subs(m=x,y));
First 1146 1147 1148 1149 1150 1151 1152 Last Page 1148 of 2460
