Hi everybody
In the following attached file that is a simple code, 2 problems occur:
1- The values of Lc1 and Lc2 are specified in the third and fourth lines of the code. when I execute Pcl10, Maple does not replace Lc1 with its value that is 0.5*L. This problem does not happen for Tcl10 and Tcl21. Why Maple does not replace Lc1 with its value that is specified at the start of the worksheet?
2- In the last line, when I try to simplify the Tcl10, Maple returns an error, while for example the first element i.e. Tcl20(1,1) can be simplified as: cos(thet1+thet2). What is the source of error?
P1.mw
I had another problem whereby I need to shaded a region between y=ln(x+2) , y-axis and y=-1 to y= 2. What is the suitable comand I shall apply ( Maple 18)
Trying to build a block matrix. Having a problem getting the syntax correct. Can't add in the predefind matrices to the lower band.
interface(displayprecision = 5)
5
interface(rtablesize = 81)
10
S := 2
dmax := 7
7
CCnew0 := Matrix(2, 2, {(1, 1) = 336750255587/3769550688757, (1, 2) = -14853552191797/1696297809940650, (2, 1) = 665096091/76929605893, (2, 2) = 1328910382993/11539440883950})
CCnew1 := Matrix(2, 2, {(1, 1) = 49655436033349/56543260331355, (1, 2) = -75647656451147/1413581508283875, (2, 1) = 29849106694/384648029465, (2, 2) = 10591394356218/9616200736625})
CCnew2 := Matrix(2, 2, {(1, 1) = 299962512141959/80776086187650, (1, 2) = -1231816081155781/8481489049703250, (2, 1) = 155175716729/549497184950, (2, 2) = 260449617208489/57697204419750})
CCnew3 := Matrix(2, 2, {(1, 1) = 50445725001719/5769720441975, (1, 2) = -9065291388901/40388043093825, (2, 1) = 21111399914/39249798925, (2, 2) = 2819495262394/274748592475})
CCnew4 := Matrix(2, 2, {(1, 1) = 142685068141037/11539440883950, (1, 2) = -116560067351321/565432603313550, (2, 1) = 44654487647/78499597850, (2, 2) = 53741323977599/3846480294650})
CCnew5 := Matrix(2, 2, {(1, 1) = 60560690824604/5769720441975, (1, 2) = -88774498025543/848148904970325, (2, 1) = 12484906049/39249798925, (2, 2) = 65745570806567/5769720441975})
CCnew6 := Matrix(2, 2, {(1, 1) = 20398649489879/4121228887125, (1, 2) = -5446073753219/242328258562950, (2, 1) = 14465459393/196248994625, (2, 2) = 8502096238511/1648491554850})
S*dmax
14
M1 := Matrix(S*dmax, S*dmax, [Matrix(S*(dmax-1), S), Matrix(S*(dmax-1), shape = identity), Matrix(S, S*dmax, [seq(-CCnew || n, n = 0 .. dmax-1)])])
Error, (in Matrix) this entry is too tall or too short: Matrix(2, 14, {(1, 1) = -336750255587/3769550688757, (1, 2) = 14853552191797/1696297809940650, (1, 3) = -49655436033349/56543260331355, (1, 4) = 75647656451147/1413581508283875, (1, 5) = -299962512141959/80776086187650, (1, 6) = 1231816081155781/8481489049703250, (1, 7) = -50445725001719/5769720441975, (1, 8) = 9065291388901/40388043093825, (1, 9) = -142685068141037/11539440883950, (1, 10) = 116560067351321/565432603313550, (1, 11) = -60560690824604/5769720441975, (1, 12) = 88774498025543/848148904970325, (1, 13) = -20398649489879/4121228887125, (1, 14) = 5446073753219/242328258562950, ...
M2 := Matrix(S*dmax, S*dmax, [Matrix(S*(dmax-1), S), Matrix(S*(dmax-1), shape = identity)])
M2 := Matrix(14, 14, {(1, 1) = 0, (1, 2) = 0, (1, 3) = 1, (1, 4) = 0, (1, 5) = 0, (1, 6) = 0, (1, 7) = 0, (1, 8) = 0, (1, 9) = 0, (1, 10) = 0, (1, 11) = 0, (1, 12) = 0, (1, 13) = 0, (1, 14) = 0, (2, 1) = 0, (2, 2) = 0, (2, 3) = 0, (2, 4) = 1, (2, 5) = 0, (2, 6) = 0, (2, 7) = 0, (2, 8) = 0, (2, 9) = 0, (2, 10) = 0, (2, 11) = 0, (2, 12) = 0, (2, 13) = 0, (2, 14) = 0, (3, 1) = 0, (3, 2) = 0, (3, 3) = 0, (3, 4) = 0, (3, 5) = 1, (3, 6) = 0, (3, 7) = 0, (3, 8) = 0, (3, 9) = 0, (3, 10) = 0, (3, 11) = 0, (3, 12) = 0, (3, 13) = 0, (3, 14) = 0, (4, 1) = 0, (4, 2) = 0, (4, 3) = 0, (4, 4) = 0, (4, 5) = 0, (4, 6) = 1, (4, 7) = 0, (4, 8) = 0, (4, 9) = 0, (4, 10) = 0, (4, 11) = 0, (4, 12) = 0, (4, 13) = 0, (4, 14) = 0, (5, 1) = 0, (5, 2) = 0, (5, 3) = 0, (5, 4) = 0, (5, 5) = 0, (5, 6) = 0, (5, 7) = 1, (5, 8) = 0, (5, 9) = 0, (5, 10) = 0, (5, 11) = 0, (5, 12) = 0, (5, 13) = 0, (5, 14) = 0, (6, 1) = 0, (6, 2) = 0, (6, 3) = 0, (6, 4) = 0, (6, 5) = 0, (6, 6) = 0, (6, 7) = 0, (6, 8) = 1, (6, 9) = 0, (6, 10) = 0, (6, 11) = 0, (6, 12) = 0, (6, 13) = 0, (6, 14) = 0, (7, 1) = 0, (7, 2) = 0, (7, 3) = 0, (7, 4) = 0, (7, 5) = 0, (7, 6) = 0, (7, 7) = 0, (7, 8) = 0, (7, 9) = 1, (7, 10) = 0, (7, 11) = 0, (7, 12) = 0, (7, 13) = 0, (7, 14) = 0, (8, 1) = 0, (8, 2) = 0, (8, 3) = 0, (8, 4) = 0, (8, 5) = 0, (8, 6) = 0, (8, 7) = 0, (8, 8) = 0, (8, 9) = 0, (8, 10) = 1, (8, 11) = 0, (8, 12) = 0, (8, 13) = 0, (8, 14) = 0, (9, 1) = 0, (9, 2) = 0, (9, 3) = 0, (9, 4) = 0, (9, 5) = 0, (9, 6) = 0, (9, 7) = 0, (9, 8) = 0, (9, 9) = 0, (9, 10) = 0, (9, 11) = 1, (9, 12) = 0, (9, 13) = 0, (9, 14) = 0, (10, 1) = 0, (10, 2) = 0, (10, 3) = 0, (10, 4) = 0, (10, 5) = 0, (10, 6) = 0, (10, 7) = 0, (10, 8) = 0, (10, 9) = 0, (10, 10) = 0, (10, 11) = 0, (10, 12) = 1, (10, 13) = 0, (10, 14) = 0, (11, 1) = 0, (11, 2) = 0, (11, 3) = 0, (11, 4) = 0, (11, 5) = 0, (11, 6) = 0, (11, 7) = 0, (11, 8) = 0, (11, 9) = 0, (11, 10) = 0, (11, 11) = 0, (11, 12) = 0, (11, 13) = 1, (11, 14) = 0, (12, 1) = 0, (12, 2) = 0, (12, 3) = 0, (12, 4) = 0, (12, 5) = 0, (12, 6) = 0, (12, 7) = 0, (12, 8) = 0, (12, 9) = 0, (12, 10) = 0, (12, 11) = 0, (12, 12) = 0, (12, 13) = 0, (12, 14) = 1, (13, 1) = 0, (13, 2) = 0, (13, 3) = 0, (13, 4) = 0, (13, 5) = 0, (13, 6) = 0, (13, 7) = 0, (13, 8) = 0, (13, 9) = 0, (13, 10) = 0, (13, 11) = 0, (13, 12) = 0, (13, 13) = 0, (13, 14) = 0, (14, 1) = 0, (14, 2) = 0, (14, 3) = 0, (14, 4) = 0, (14, 5) = 0, (14, 6) = 0, (14, 7) = 0, (14, 8) = 0, (14, 9) = 0, (14, 10) = 0, (14, 11) = 0, (14, 12) = 0, (14, 13) = 0, (14, 14) = 0})
lowerband := Matrix(S, S*dmax, [seq(-evalf(CCnew || n), n = 0 .. dmax-1)])
lowerband := Matrix(2, 14, {(1, 1) = -0.893343e-1, (1, 2) = 0.875645e-2, (1, 3) = -.878185, (1, 4) = 0.535149e-1, (1, 5) = -3.71351, (1, 6) = .145236, (1, 7) = -8.74318, (1, 8) = .224455, (1, 9) = -12.36499, (1, 10) = .206143, (1, 11) = -10.49630, (1, 12) = .104669, (1, 13) = -4.94965, (1, 14) = 0.224740e-1, (2, 1) = -0.864552e-2, (2, 2) = -.115162, (2, 3) = -0.776011e-1, (2, 4) = -1.10141, (2, 5) = -.282396, (2, 6) = -4.51408, (2, 7) = -.537873, (2, 8) = -10.26209, (2, 9) = -.568850, (2, 10) = -13.97156, (2, 11) = -.318088, (2, 12) = -11.39493, (2, 13) = -0.737097e-1, (2, 14) = -5.15750})
(14)
M3 := Matrix(S*dmax, S*dmax, [Matrix(S*(dmax-1), S), Matrix(S*(dmax-1), shape = identity), lowerband])
Error, (in Matrix) this entry is too tall or too short: Matrix(2, 14, {(1, 1) = -0.8933432215e-1, (1, 2) = 0.8756453086e-2, (1, 3) = -.8781848755, (1, 4) = 0.5351488825e-1, (1, 5) = -3.713506389, (1, 6) = .1452358276, (1, 7) = -8.743183575, (1, 8) = .224454831, (1, 9) = -12.36498974, (1, 10) = .2061431666, (1, 11) = -10.49629552, (1, 12) = .1046685287, (1, 13) = -4.949652167, (1, 14) = 0.2247395242e-1, (2, 1) = -0.8645515381e-2, (2, 2) = -.1151624586, (2, 3) = -0.7760109089e-1, (2, 4) = -1.101411529, (2, 5) = -.2823958356, (2, 6) = -4.514076892, (2, 7) = -.537872817, (2, 8) = -10.26209174, (2, 9) = -.5688498906, (2, 10) = -13.97155838, (2, 1...
Download Test_Block_matrix.mw
5
10
S := 2
dmax := 7
7
S*dmax
14
(14)
I wold like to find the solution of the next system of two equations with three unknowns but we assume that the unknows are positive integers. How the following code can work. Many thanks
> restart;
> assume(J, integer, J >= 0);
> assume(A, integer, A >= 0);
> assume(T, integer, T >= 0);
> eq1 := J+10*A+50*T=500;
   eq2 := J+A+T = 100;
  solve( {eq1,eq2},{J,A,T});
For many years I succesfully used the command:
Lambda := ImportMatrix(LambdaFile, delimiter = "", datatype = string);
but for some txt files I now got the following error in Maple 2016:
Error, (in ImportMatrix) cannot interpret file
The same code still runs without problems at all in previous versions of Maple.
The strange thing is that other txt files can be still be imported in Maple 2016 without problems.
I will upload two files:
ULSlx3.txt returns an error message
ULStd3.txt no problems
ULSlx3.txt
ULStd3.txt
complete code:
with(LinearAlgebra); with(Statistics);
interface(rtablesize = infinity);
with(Typesetting):
interface(typesetting=extended):
LambdaFile := "C:/path/ULSlx3.txt";
Lambda := Matrix(5, 1);
in the whatsnew there is no information on changes with respect to the ImportMatrix command, although there is some (unrelated) information on Importing Data:
Importing Data
By default, the Import command now returns a DataFrame when importing from Excel, CSV, DIF, and TSV file formats, and returns a DataSeries when importing from ODS, SXC, and TSV file formats. Use the output option to specify a different format. For example, Import(origin, output=Matrix).
I have no clue what is wrong with my code and why some text files can be imported as before whereas other files returns an error message.
greetings Harry
In using Maple there are many ways to complete a command on a function. Using shortcuts in the worksheet/document you can enter the command on the line rather than using the drop down menus or clickable math menu.  I would like to see what the shortcut command are for the packages in Maple.  There are so many, I am using the LinearAlgebra package and have seen Dr. Lopez use " ||A||2 to determine the Euclidean Norm of A.  But where does this use get described in the help or examples of other shortcut usage for Maple. I've seen the shortcut commands for Documents in General, but the use of shortcut commands for other packages  don't seem to discuss the usage of such shortcuts.
Is there a document that documents these shortcuts.
Hi my dear friends, sorry for boring you. I am hauted by a problem about 'mtalyor'.
I failed to expand the following equation by using the following command:
u:=x(t)/sqrt(x(t)^2+y(t)^2-2*x(t)+1)*diff(y(t),t);
indets(u,name);
w:=evalindets(u,function(identical~({x(t),y(t)})),s->op(0,s)(freeze(op(s))));
var:=indets(w,name) minus {t};
mtaylor(w,var,4);
thaw(%)
 Freeze is applied to the part in which the expansion will take place, obviously it didn't work well.
Thank you in advance for taking a look.
To gererate a random initail cofigration -1 or 1
spin = (-1).^(round(rand(N)));
for i=1:1000,
neighbours = circshift(spin, [ 0 1]) + ...
circshift(spin, [ 0 -1]) + ...
circshift(spin, [ 1 0]) + ...
circshift(spin, [-1 0]);
how to do this in maple?
I was looking for information on how to solve a differential equation in Maple, but I do not know how to start.
I have yet equations in symbolic form and I want to apply for the calculation of such a procedure ODE4 (Runge Kutta 4) with fixed step integration Tc and time calculations ongoing T.
Where to start?
1. This should be done in another sheet, or I could write command in next line under the symbolic transformations?
2. To enter numeric parameters that certain symbols were they equal?
3. How to perform iterative calculations?
Thank you in advance for your help
Dear friends,
after looking through your site for some time I could not find any instructions on how to change my avatar (green caleidoscope pattern at this time). Could you advise me on this? Thank you.
Best regards,
Marko Riedel
PS: If you are answering this, when I enter my website into my profile it says the link is invalid, could that possibly be because there is a tilde in the link and therefore it fails to match a regular expression somewhere? Could we get a more precise error message from the profile validator?
I am curious, can simplify/siderels be executed in mod p by some equivalent Maple function call?
Hi, I have the equations (below) with different parameters. I'd like to find out if is it possitble to:
(1) Create a loop that solves for values of on of the parameters, T, in the interval -0.3<T<0.3 and obtain the solutions allowing for a grid of 0.01.
That is, if one can first solve for T= -0.3 and then use the loop with increments that raise T by 0.01 each time until T=0.3. Other parameters are held constant at their assigned values.
(2) Generates the corresponding vectors for T and all the endogenous variables.
eq1 := PI_T = alpha*M*(kappa/(1+kappa-sigma)-1):
eq2 := l = alpha*((sigma-1)*kappa/(1+kappa-sigma)+1):
eq3 := M = phi_c^(-kappa)*F:
eq4 := e*F = PI_T*v+T:
eq5 := M*l+L_A = L_s:
eq6 := F*e+A = A_s:
eq7 := A = (1-beta)*(L_s+(1-v)*PI_T-T):
eq8 := A_s = L_A:
eq9 := p = sigma/((sigma-1)*phi):
eq10 := P_Y = M^(lambda/(1-sigma))*p:
eq11 := L_s = N*(theta*P_Y^beta)^(-1/delta):
eq12 := phi = (kappa/(1+kappa-sigma))^(1/(sigma-1))*phi_c:
eq13 := U = delta*theta*L_s/((1+delta)*P_Y^beta)+((1-v)*PI_T-T)/P_Y^beta:
Params:= [ T=0, N = 1, v = 1, beta = .75, lambda = 1, sigma = 5, kappa = 4.8, delta = 2, theta = 2.591350635, alpha = 0.3998699153e-1, e = 0.8333333332e-1]:
Init_Values:= {A_s = .2500000000, l = .9996747882, PI_T = 0.8333333332e-1, L_A = .2500000000, phi = 1.878101496, M = .4168022157, A = .1666666667, p = .6655657336, P_Y = .8283396488, L_s = 2/3, phi_c = 1.2, F = 1, U = 1.326439132 }:
SOL:= fsolve(eval({eq||(1..13)}, Params), Init_Values);
Many thanks!!
Hello there,
Suppose I have a parametric experssion like   P(ε)=1+ε+ε23 where ε is very small. How can I get P(ε)≈1+ε or P(ε)≈1+ε+ε2
I would like to remove from a table, the index that verifies some constraint.
For example :
a := table([1=c, 2=g, 3=y]);
for k in [indices(a, `nolist`)] do
  if is(k, even) then
    a[k] := 'a[k]':
  end if:
# This does not work as expected
eval(a);
I have found this workaround
b := map(u -> if `not`(is(u, even)) then u=a[u] end if, [indices(a, `nolist`)]);
eval(b);
But is there a way to force Maple to evaluate k to 2 before it "unevaluate"  'a[k]' ?
I would like to know , what is the command that i able to carry out (simple one) such that I able to shaded the region between y=x^2 and y-axis from y= 0 to y=4.
First 1153 1154 1155 1156 1157 1158 1159 Last Page 1155 of 2463
