Given some points, how do I find the polynomial/exponential function best matches them?
points are:[[1030, 0], [380, 34], [270, 73], [240, 150], [85, 700], [22, 2000], [12, 5000]]
And here is a image too.
Points
How do I multiply the 4x into the summation to get  (Sum(4*n*a[n]*x^(n), n = 0 .. infinity))  and same idea for the 3rd third?
Also, how do I go from   Sum(a[n-2]*x^(n-2), n = 2 .. infinity)  to  Sum(a[n]*x^(n), n = 0 .. infinity)  by manipulating the indices?
Is there any way to include EVERY possible, relevent function in the context sensitive menu?  I know this would be a lot so there will need to be submenus.
Hello, I'm new to Maple and have a problem with making some electrical engineering.
I miss the unit VA (volt-ampere) which is used in AC. Maple won't recognize it and when I type it separately it changes to W (watt).
Hope someone can help me, thank!
By the way, how do you insert "Maple Code" in here?
I have written the following coade in Maple:
r := 50;
l1 := 0.2742e-10;
s := I*w;
l := (-1.342110665*10^22*c^2*(Pi^4)-4.225000000*10^25*c^2*(Pi^2)+2.316990000*10^11*c1*(Pi^2)-1)/(-1.342110665*10^22*c^2*c1*(Pi^4)-7.140250000*10^43*c^2*c1*r^2*(Pi^4)+1.957856550*10^33*c^2*(Pi^4)+9.789282750*10^32*c*c1*(Pi^4)-1.690000*10^22*c*(Pi^2)-4.22500*10^21*c1*(Pi^2));
z1 := (c*l1*s^2+1)/(c*s);
z2 := l*s/(c1*l*s^2+1);
h := (z1+2*z2)*((z1+2*r)*(z1+3*z2)/(2*r)-2*z2)/z2-(1/2)*z2*(z1+2*r)*r;
f := h*(z1+3*z2)/z2-(z1+2*r)(2*r)*(z1+3*z2)+2*z2;
gain := 2*z2/f;
a := abs(gain);
d := diff(a, w);
s := subs(w = 2*pi*0.325e11, d)
Now, I have a function named "s" which I want to set to zero, and calculate the relationship between variables c & c1 in order to achieve this. How should it be done?
When I execute the command
series(exp(x),x)
and then refer to the equation in a new execution group using a equation label (CTRL-L on Windows), the equation is shown in Maple 18, but in Maple 2015 I get an error message: 'Error, missing operator or ';'. Using the % instead does work for both versions.
Is this intended behaviour or a bug in Maple 2015?
Bart
how to plot ln(sqrt(x-12)/(-x^(2)+15x)
Whenever I try to plot I get
"Warning, unable to evaluate the function to numeric values in the region; complex values were detected".
HELP PLEASE
Hi everyone--my differential equations course is using Maple; this is my first time using the program and I am a little cofused.
In a lab component we are told to take the differential equation " dy/dx = sin (x - y) " and substitute in y = ax+b, then determine which coeffecients of a and b should be in order to obtain a solution.
I have made many attemps at this substitution, but am encountering syntax errors no matter what I do:
http://imgur.com/WVQsUQy
I know the general equation would be written in Maple as
..which presents no problems for me, format-wise, and generates a nice output.
However, any iteration I've tried with substituting y = ax+ b has resulted in an error like those shown in the linked image above; I'd really appreciate it if someone could explain how I would do the substitution and maybe what I'm doing wrong, syntax-wise.
Thank you for your time!
I'm having trouble with using constrained optimization to solve a problem.
The problem is set up as:
Max: w=x1/2 y1/4
Subject to: K=x+4. K is a constant.
I'm not sure where to start.
I want to solve a cubic equation as is attached here. I solved it in my Maple file which is attached too. But mu result differs from that is showed in the picture. help me please.
Cubic_Eq.mw
map(f, foldl(`*`, 1, a, b));
foldl(`*`, 1, map(f,a), map(f,b));
map(f, foldl(`+`, 0, a, b));
foldl(`+`, 0, map(f,a), map(f,b));
i discover it can auto calculate ring homomorphism,
if i define a function f below
factor(map(f, foldl(`*`, 1, a, b))+map(f, foldl(`*`, 1, b, c))) = map(f, foldl(`*`, 1, a, c));
how to convert this f into a function with two input parameters?
 from permutation group to permutation group and inverse this mapping?
how to do?
how can I plot the phase portrait of this system?
Sys := {diff(x(t),t) = y(t)-2*(x(t))^2, diff(y(t),t) = -8*(x(t))^3+4*x(t)*y(t)-5*(x(t))^4-(x(t))^5};
    The following code displays values of the subscripted variables slf[], a positive integer, and a string variable filler[] which is just a set of spaces depending on how big the corresponding value of slf[] s.  This is to make the printout lined up nicely.
printf("%s%d%s%d%s%d%s%d%s%d%s%d%s%d%s%d%s%d%s%d\n", filler[1],slf[1],filler[2],slf[2],filler[3],slf[3],filler[4],slf[4],filler[5],slf[5],filler[6],slf[6],filler[7],slf[7],filler[8],slf[8],filler[9],slf[9],filler[10],slf[10]);
   This works fine,but thought there might be a better way.  I tried:
printf("%s%d%s%d%s%d%s%d%s%d%s%d%s%d%s%d%s%d%s%d\n",seq(filler[k],slf[k],k=1..10));
but this came up with an error message.  Is there  a way of doing this more efficiently?
thanks,   David
guys,i computed a tensorial expression by maple but i think i made mistake.
tensorial.mw
First 1170 1171 1172 1173 1174 1175 1176 Last Page 1172 of 2434
