How do I delete files I have uploaded in my file section?
Is it possible to convert Pa*m^2 to Newton? (5) 13200. m Pa > convert(13200.*m^2*Pa, 'Units', 'N'); %; Error, (in Units:-Standard:-convert) unrecognized conversion > I don't know how to convert this to Newton (In maple), and I know that it is possible in the real world. Any help available? I know how to do it if I don't use maple or input my own units
help! How to make Maple cancel the common expressions in both
denominator and numerator?
As you could see, there is a g^(2/3) which is a common factor...
http://yfrog.com/0rexpression2j
I really want it to be removed.
Thanks a lot!
we have the following:
  CM := MultiSeries:-series((c[1]*e+c[2]*e^2+c[3]*e^3+c[4]*e^4+O(e^5))^m, e)
CM := c[1]^m*e^m+c[2]*m*c[1]^m*e^(1+m)/c[1]+(1/2)*m*(2*c[3]*c[1]+c[2]^2*m-c[2]^2)*c[1]^m*e^(2+m)/c[1]^2+(1/6)*m*(6*c[4]*c[1]^2+6*c[3]*c[2]*c[1]*m-6*c[3]*c[2]*c[1]+c[2]^3*m^2-3*c[2]^3*m+2*c[2]^3)*c[1]^m*e^(3+m)/c[1]^3+O(e^(4+m))
I am helping a friend.
Please see the two expressions that we would like to convert from Maple into Matlab:
http://yfrog.com/jdexpression3j
In the first one, why doesn't Maple first calculate g1^(2/3) and g2^(2/3) as common expressions, then use them to calculate the whole expression?
The (0.1e1/0.3e1) stuff looks very bad.
In the second one, we just couldn't get Maple to cancel the common factor g1^(2/3) in both numerator and denominator before doing the conversion to Matlab.
Initial conditions,     x(0)=2, D(x(0))= -2
D= differential
D2x +5Dx +4x = delta( t - 2 )
I want to check my answer in maple but i cant get it to work.
This is the answer i gt by hand
x = H( t - 2 ) ( ( e ^ - 4 ( t - 2 ) + e ^ - ( t - 2) ) / 3 ) - 4 / 3 e ^ - 4 ( t - 2 ) + 10 / 3 e ^ - ( t - 2 )
I have this code and to test if it works in TextField1 next to the label "MATRIZ A" I enter
I'd like Maple to see that the derivative of p1 with respect to X includes p1 and p2
> p1 := exp(a*x)/(exp(a*x)+exp(b*x)+1);
> p2 := exp(b*x)/(exp(a*x)+exp(b*x)+1);
> m := eval(diff(p1, x));
> n := expand(m);
I see that algsubs won't work along the lines of
   algsubs(exp(a*x)/(exp(a*x)+exp(b*x)+1)=p1,n)
because the substitution is not a polynomial.
any other way to do this?
I have the curve: f(x) = 1/x^3.
I want to find the coordinates of a point on this curve that is the nearest to the point P = (0,1)
How can I find this with Maple?
thanks, Anders
how to plot the second picture,for the area is that with abs
If  we have two 1-dimensional arrays containing 'n' elements  each  and we want to compare the corresponding elements of the arrays (i.e., k th element of one array to the k th element of the other ). And the output that we are bothered about is that the corresponding element of both the arrays are equal (ie, one to one correspondence holds). Is there any simpler way to do this in maple. Somebody please help.
Does Maple have a command for return true or false when querying set membership of an element?
I have sets of random integers, Stuff[k], indexed by k, for example
Stuff[9]:={2,5,6}:
I need to be able to test if
7 is a member of Stuff[9]: // I should get false
5 is a member of Stuff[9]: // I should get true
There is no such set membership function listed in the Help menu.
I finally figured out a for loop for sequentially removing one set from another (set-theoretic subtraction).
Below is the code found on this site for generating the mandelbrot set.
with(ImageTools):
MyMandel := proc(pt)
local i,z,c;
c := pt;
if abs(c) > 2 then
return 1;
z := c;
for i from 2 to 100 do
z := z^2 + c;
if abs(z) > 2 then
return i;
end if;  end do:
return 0;
end if; end proc;
GenerateComplex := proc(pts,X1,X2,Y1,Y2)
option evalhf;
local X::Vector, Y::Vector, f1::Vector, Z::Vector;
First 2073 2074 2075 2076 2077 2078 2079 Last Page 2075 of 2434
