 (2x-a/x+a)-(x+3a/a-x)-(a^2/a^2-x^2)
hey
let me put it simple: in maple if I do
However,
if i do l := list(30); l[1] := 2; l[2] := 2; l[3] := 3; l[4] := 3; l[5] := 5; l[6] := 7
I have following program and get error
>f := (x,y) -> `if`(x>1, x+y, x-y);
>f(1.1,0.1);#function without int evaluated correctly
                                     1.2
>ff := (y) -> int(f(x,y), x=-2.0..2.0);
>evalf(ff(1.2));
Error, (in eval/if) cannot determine if this expression is true or false: 1 < x
I have the differential equation below
de1:=diff(F(eta,alpha,R),eta$4)+alpha*eta*diff(F(eta,alpha,R),eta$3)+2*alpha*diff(F(eta,alpha,R),eta$2)-R*(diff(F(eta,alpha,R),eta)*diff(F(eta,alpha,R),eta$2)-F(eta,alpha,R)*diff(F(eta,alpha,R),eta$3));
How do I evaluated it with a series representationtation of F like the one below
F(eta,R,alpha)=add(add(F[n,k](eta)*R^n*alpha^k,k=0..10),n=0..10);
i tried using the subs command to substitute it in but just got back what i started with
Dear OpenMaple users,
we try to tackle the following problem (unfortunately with limited success):
We would like to use OpenMaple (Maple 12) to call a maple procedure from C (C++ with only C features used). We have the void-function myfunction which gets two n x d arrays (d<=20, called inputmatrix and outputmatrix), a double parameter myparameter, a MKernelVector kv, and an ALGEB r.
Hello! My question is how I can decompose, for example, sin(x) to infinite product. Something like this: Pi*z*Product(1-z^2/n^2,n = 1 .. infinity) = sin(Pi*z) Thanks
hi I want to write a program that convert a polygon to triangle, that is if we have polygon with 6 edges, how we can get triangle from it using edges or vertices??
I am biginner,
It is well know that the quintic equation is not solved by radicals generally. Although the solution for quintic equation is expressed explicitly by using Jacobi theta functions, in the following site I tried to find a differential equation as a solution for inverse function of general quintic polynomial, and found it is expressed with the 5-th degree nonlinear differential equation.
http://hecoaustralia.fortunecity.com/stbruno/stbruno-s.htm
Would appreciate some guidance for this question:
If q = ax + by and r = bx - ay, determine the value of:
Hi everybody
I am doing this calculation:
I have my maple code as follows. I don't see why I got "Error, invalid subscript selector"? can anybody help me? Thanks in advance!!
>a := [2, 2, 3, 3, 3, 5];
b := [2, 2, 2, 3, 7];
for k to 10 do
  for j to 10 do
       c := b[k]; d := a[j];
if c = d then a := subsop(j = NULL, a);
    print(a);
     print(k);
    print(j);
     break
else print(k);
Hi, all
I tried by:
>alias(a=RoofOf(z^4+z+1)):
> if a > 2 then print('yes') end if;
Error, cannot determine if this expression is true or false: 2 < RootOf(_Z^4+_Z+1)
Any ideas?
I want to write a programme that convert a polygone into triangle, Can any one help me please.
i am new to maple.
I created three different matrices which are A,B and C. I tried to calculate 4(AB)C but when I command it,it gives me an error. Does anyone know how can I do that?
I also need to create a system of three different linear equations with unknown that has one solution. My equations are 2x+3y=8 -x+2y=3 and 3x-4y=-5.Can anyone tell me how can I plot these lines, solve the system by using solve command and how can I solve the system using by matrices and row operations?
I'm trying to find my way around using pdsolve. The problem I have now is how to handle the result it return me. From the psdolve help page, for example, we have the following equation returned (eq. 1.2) :
f(x, y) = _F1(x^2+y^2)
First 2192 2193 2194 2195 2196 2197 2198 Last Page 2194 of 2459
