Maple gives solution to equation as RootOf when there is no explicit solution
eq:=x*sin(x*y)+y+1=0;
sol:=solve(eq,y)
The _Z above, is the variable we wanted to solve for, which is in this example. My question is, why did not Maple give the solution as
sol2:=RootOf(x*sin(_Z*x)+_Z+1)
Which is a little simpler looking. Is the above not the same as what Maple gives?  I just replace by _Z
Digits:=100;
plot(evalf(sol-sol2),x=0..Pi)
The uploaded worksheet contains the general definition of a pedal curve related to the curve [f(t),g(t)], and includes several example pedal curves.
Is there a comparable general definition of a pedal surface? If so, in your answer please include the Maple code for one or two simple examples e.g. relating to a sphere, to an ellipsoid.
To everyone in the Maple Forum community, Happy Holidays and a fulfilling New Year!
Pedal_curves.mw
If the equation with homogeous coordinates in the base (A,B,C) is pYZ+qZX+rXY=0, an affine  equation in the base (A,AB,AC) is
pxy+qy(1-x-y)+r(1-x-y)=0, it is also written rx²+(q+r-p)xy+qy²=0. The discrim of  trinom is rx²+(q+r-p)xy+qy² is of the sign of
delta=(q+r-p)²-4qr; We get a hyperbole, a parabole, an ellipse according to delta is >0, =0 or <0 respectvely. How implement
this property. Thank you very much.
Here is my try to integrate the expression L with trapozoid or simpson
numerical_int.mw
Just to inform me about the options to add in my code , to have a style similar to the  picture..
QuestionOptionVolume.mw
Why do I get this wrong result when I try to solve formally this ode (note that acer has already obtained its implicit form here implicit)
interface(version)
Standard Worksheet Interface, Maple 2015.2, Mac OS X, December 21 2015 Build ID 1097895
edo := diff(y(x), x, x) = 1/y(x) - x*diff(y(x), x)/y(x)^2;
ic  := y(0)=1, D(y)(0)=0:
dsolve({edo, ic}, y(x));
eval(edo, %)
                                        / d      \
                                      x |--- y(x)|
               d  / d      \    1       \ dx     /
              --- |--- y(x)| = ---- - ------------
               dx \ dx     /   y(x)          2
                                         y(x)
                            y(x) = 1
                             0 = 1
sometimes Maple's solution for an ode is not valid for all x. When I run odetest on the solution, it is not zero.
For the case when the output of odetest contains one csgn(), I am trying to determine if odetest result will become zero, when csgn is +1  or -1. If so, then next look into the argument of csgn and solve for x under this condition and hence find the range of x when the solution is valid.
I wrote the following to do this and check the idea.
I'd like to ask if the Maple experts here can suggest improvement or if there a better way to do this.
The code below works if there is only instance of csgn() in the output of odetest. Which covers almost all the cases I saw so far.
The code first checks if csgn is present in the output of odetest. If so, it then uses indents to pick up the function csgn out. Then uses op to pick its argument. Then uses solve with inquality to find when the argument is either positive or negative. This results in the range of x needed to make odetest zero.
This is just a quick prototype to test the idea. This not the final code I will be using as that will include more checks and be more robust.
ode :=diff(y(x),x)=2*(x*sqrt(y(x))-1)*y(x):
ic  :=y(0)=1:
sol :=dsolve([ode,ic]):
res :=odetest(sol,ode);
So we see odetest did not give zero.  The issue is that I can't just do
solve(res=0,x)
It does not work.  So that is why I had to look inside as follows:
The goal is to check if when csgn is either +1 or -1, if it will then become zero.
And if so, then also find the range of x which will caused this.  In the above, we see that when 1/(x+1) is +1, then odetest result  will become zero. This means x has to be larger than -1.
Note that this is all done in code, without being able to look at the screen and then decide what to do
if res<>0 then
    if has(res,csgn) then
        if simplify( subsindets(res,csgn(anything),f->1)) = 0 then
            print("the odetest becomes zero when csgn is POSITIVE");
            Z:=indets(res,specfunc(csgn));
            the_args:=map(x->op(x),Z);
            print("Now solve ",the_args," for x, when the expression is POSTIVE");
            for tmp in the_args do
                result:=solve(tmp>0,x);
                print("the solution is valid for x>", op([1,1],result));
            od;
            if simplify( subsindets(res,csgn(anything),f->-1)) = 0 then
                print("Now solve ",the_args," for x, when the expression is negative");
                    result:=solve(tmp<0,x);
                    print("the solution is valid for x<", op([1,1],result));
                od;
                print("give up. Tried when csgn is positive or negative");
            fi;
        fi;
    fi;
fi;
If there is more than one csgn function in the odetest result, it will become much more complicated, since one have to check all combinations to find under which combination odetest will become zero. So for now, I am just doing this only for one case of csgn present.
I have a function defined by this integral: f(x):=int((sin(t)^2)^(exp(t)),t=x..infinity). The question is how to plot this function from x=-5 to x=+5 in Maple 2020? I do as follow, but it does not work for Maple 2020 (15 days trial version).
f := int((sin(t)^2)^exp(t), t = x .. infinity)
plot(f, x = -5 .. 5)
Maple version: Maple 2020.2, Maple Build ID 1502365.
Not that I can't sleep quietly without it, but why is the possibility of receiving a vote or being selected as the best answer (ok, this rarely happens) no longer proposed in my replies?
For instance, in a recent reply (not the one I'm the prouder of) the header appears like this, witho ot thum nor star below "1 hour ago")
TIA
Please see the question posed in the opening text of the uploaded worksheet.
Oloid.mw
I have a function:
T(t) := (t+459.47) * 5/9  ,  convert degrees F to Kelvins.
I want to produce a table of values over a range of 100F to 250F with two colums,
Degrees F and Kelvins.
I have no problem doing this in Mathcad Prime, but I'm lost as to how
to accomplish this in Maple.
I am evaluating the Maple trial as a potential replacement for Mathcad Prime,
but at this point it may not work for me.
I am trying to verify the general solution to the nonlinear ode
diff(y(x), x, x) = 1/y(x) - x*diff(y(x), x)/y(x)^2  (1)
Maple says this expression is invalid when I try to enter it using the button.  I can copy and paste this expression into maple, however, and it works fine.
I take the second derivative of the general solution, then use the solve(solution, diff(y(x),x,x) command to try to put the second derivative in the form of (1).  The result from this command does not match the original ode, but the odetest( ) funtion returns a value of zero.
How do I "manually" verify this solution with maple?  I am investigating a certain type of equation, and my solution technique so far involves rewriting the equation into a different form (nonlinear PDE) and then solving the PDE.  I am building up maple skills to eventually do that.
For your reference, this equation is from a maple help page:
https://www.maplesoft.com/support/help/maple/view.aspx?path=odeadvisor/exact_nonlinear
I would really appreciate some help with this,
Steve :)
Hello everyone !
I would like to know if there's a way to get simplified expressions for multivariables expressions...
for a simple example :
expand((a+b)^2) returns a²+b²+2ab
how could I get (a+b)^2 from a²+b²+2ab ?
for a more complicated example :
factor([2*x^3 - 6*x*y*z + 2*y^3 + 2*z^3])
returns :
        [2 (x + y + z) (x²  - x y - x z + y²  - y z + z²)]
but since :
2*(x²  - x y - x z + y²  - y z + z²) = (x - y)^2 + (y - z)^2 + (z - x)^2
is there a way to get that kind of simplification ?
thank you for your time
Hello everybody,
In my code, i would like to create a square matrix M of dimension 'a' (which is a ColumnDimension of an imput matrix A):
Otherwise, i have an expression ('EXPR') on alpha[i](x) and beta[i](x), i=1..b, (where b is a ColumnDimension of an imput matrix B).
The matrix M that i want to get must be M:=(EXPR(alpha[i],beta[j])),i,j=1..a, evaluated for particular alpha[i](x) and beta[j](x) wich are stored in A and B respectively.
Below, is the code that i write:
Test := proc(A, B,EXPR)
local a, b, M, i, j, k;
a := LinearAlgebra['ColumnDimension'](A);
b := LinearAlgebra['ColumnDimension'](B);
M := Matrix(a);
for i to a do for j to a do
if evalb(i = j) then
M[i, j] := M[i, j] + eval(EXPR, {seq(alpha[k] = (t -> eval(A[k, i], x = t)), k = 1 .. b), seq(beta[k] = (t -> eval(B[j, k], x = t)), k = 1 .. b)}); else
if evalb(i < j) then
M[i, j] := M[i, j] + eval(EXPR, {seq(alpha[k] = (t -> eval(A[k, j], x = t)), k = 1 .. b), seq(beta[k] = (t -> eval(B[i,K], x = t)), k = 1 .. b)}); else
M[i, j] := M[i, j] + eval(EXPR, {seq(alpha[k] = (t -> eval(A[k, j], x = t)), k = 1 .. b), seq(beta[k] = (t -> eval(B[i, k], x = t)), k = 1 .. b)}); end if;
return M;
I tested the program for A, B and EXPR given by:
A := Matrix(2, 3, [[4, x, 1/4*x^2], [2, 3, x]]);
B := Matrix(3, 2, [[3, 5], [x, 2], [1/2*x^2, -x]]);
EXPR := alpha[1](1/2)*beta[1](1/2) + int(alpha[1](x + 1/2)*beta[2](1/2*x), x = -1/2 .. 1/2) + alpha[2](1/2)*beta[2](1/2);
Maple returns the following:  Error, (in anonymous procedure called from Test) bad index into Matrix.
I understood that the problem comes from the k that I wrote in bold in the code.
I would like to evaluate the EXPR for alpha[k]:=A[k, i] and beta[k]:=B[j,k] , but I don't really know how to interpret this for maple.
Could you help me please ?
Do you have an idea ?
Best regards,
I am an electrical engineer and have been using Matlab for years.  I am switching over to Maple and am converting my extensive library of Matlab scripts to Maple.
Among other things, I plan on using Maple, as I have Matlab, to determine component values based on design criteria (e.g. input voltage range, output voltage range, etc.) and to analyze the resulting circuit uncertainties.
I have generally released the uncertainty results to my clients and like to use the appropriate mathematical symbols to convey the information.
I would eventually like to generate a report for my client that shows the calculated component values and the resulting uncertainties (e.g. "R1 = 2.56kΩ ± 0.01%", "Total uncalibrated uncertainty (maximum) = ±(0.23452% of reading + 0.198°C)")
I see that outside of a code edit region, I can freely use the symbols from the "common symbols" palette to generate text as shown above.
Should I avoid trying to automate this (i.e. using printf() statements)?
First 459 460 461 462 463 464 465 Last Page 461 of 2427
