Hi. I want to get a Fourier transform under the equation How to do this? Equation_is.docx
Greetings!
I am trying to solve a system of equations involving several symbols. The answer I am getting involves rootof...
I have tried to fix it, and read several post on MP, but in vain. Please help me to get a solution which does not involve root of solutions. Coz the paper I am follwing has a very elegant solution to these equations which i am failed to obtain via maple.rootof.mw
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/rootof.mw .
Download rootof.mw
Most of the time, odetest() returns just zero if solution satisfies ode, and non-zero expression if solution does not satisfy ode.
So I was just checking for zero as return value to check if my solution was verified or not. This works for most cases.
But there are cases when odetest returns odetest/PIECEWISE` where some cases are zero and some are not.  Example is below.
For this, I still want to consider my solution as valid if one of the cases in piecwise is zero. But I am not sure what is a robust way to do this in code. Currently, I do the following
ode:=x*diff(y(x),x) = y(x)+2*(x*y(x))^(1/2);
my_sol:=y(x)=x*(ln(x/_C1)^2 - 1) - 2*(-1 + sqrt(ln(x/_C1)^2))*x;
res:=odetest(my_sol,ode);
if res<>0 then
   if type(res,'function') then #this meant to handle PIECWISE
      print("verified");
      print("did not verify");
   fi;
else #if we come here, res=0, so I am sure it is valid.
   print("verified");
fi;
In the above, the check  type(res,'function')  is meant to catch PIECEWISE  return, since when I did type(res) Maple told me the type is function.
But I am not sure if this is a robust way to check for this, as it might be possible maple will return non zero, and also a function, but it will not be what I think it is (i.e. PIECEWISE) and then I would flag my solution as valid when it is not.
worksheet attached also.
if res<>0 then
      print("verified");
   fi;
   print("verified");
fi;
ode := x*(diff(y(x), x)) = y(x)+2*sqrt(x*y(x))
my_sol := y(x) = x*(ln(x/_C1)^2-1)-(2*(-1+sqrt(ln(x/_C1)^2)))*x
`odetest/PIECEWISE`([0, x/exp((-x+(x*y(x))^(1/2))/x) = _C1], [0, x/exp((x+(x*y(x))^(1/2))/x) = _C1], [-4*(-x^2*(-ln(x/_C1)^2+2*(ln(x/_C1)^2)^(1/2)-1))^(1/2), x/exp(-(-x+(x*y(x))^(1/2))/x) = _C1], [-4*(-x^2*(-ln(x/_C1)^2+2*(ln(x/_C1)^2)^(1/2)-1))^(1/2), x/exp(-(x+(x*y(x))^(1/2))/x) = _C1])
"verified"
Download how_to_check_odetest.mw
restart; _local(gamma); _local(I); m := 3; A := 10; delta := .112; rho := .23; beta := 1.4; alpha := 2.1; gamma := 1.02; q := 2.3; b1 := 50; b2 := 10; b3 := 5; b4 := 20; S(0) := b1; B(0) := b2; V(0) := b3; R(0) := b4; mu := .13; i = 1; for k from 0 to m do S(k+1) := (A*delta*k-(rho+mu)*S(k)-beta*(sum(S(m)*B(j-m), j = 0 .. m)))/(k+1); B(k+1) := -(-(mu+alpha+gamma)*B(k)+beta*(sum(S(m)*B(j-m), j = 0 .. m)))/(k+1); V(k+1) := (rho*S(k)-(1-q)*S(k)-mu*V(k))/(k+1); R(k+1) := (gamma*B(k)-mu*R(k))/(k+1) end do; s := sum(S(kk)*t^kk, kk = 0 .. m); b := sum(B(kk)*t^kk, kk = 0 .. m); v := sum(V(kk)*t^kk, kk = 0 .. m); r := sum(R(kk)*t^kk, kk = 0 .. m); SS(0) := s; BB(0) := b; VV(0) := v; RR(0) := r; S(0) := subs(t = T(i), s); B(0) := subs(t = T(i), b); V(0) := subs(t = T(i), v); R(0) := subs(t = T(i), r)
I
Warning, The imaginary unit, I, has been renamed _I
10
.112
.23
1.4
2.1
1.02
2.3
50
10
5
20
50
10
5
20
.13
i = 1
-18.00-1.4*S(3)*B(-3)-1.4*S(3)*B(-2)-1.4*S(3)*B(-1)-14.0*S(3)
32.50-1.4*S(3)*B(-3)-1.4*S(3)*B(-2)-1.4*S(3)*B(-1)-14.0*S(3)
75.85
7.60
3.800000000-.4480000000*S(3)*B(-3)-.4480000000*S(3)*B(-2)-.4480000000*S(3)*B(-1)-4.480000000*S(3)
52.81250000-2.975000000*S(3)*B(-3)-2.975000000*S(3)*B(-2)-2.975000000*S(3)*B(-1)-29.75000000*S(3)
-18.70025000-1.071000000*S(3)*B(-3)-1.071000000*S(3)*B(-2)-1.071000000*S(3)*B(-1)-10.71000000*S(3)
16.08100000-.7140000000*S(3)*B(-3)-.7140000000*S(3)*B(-2)-.7140000000*S(3)*B(-1)-7.140000000*S(3)
.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3)
55.85709723-1.296018889*S(3)*B(-3)-1.296018889*S(3)*B(-2)-1.296018889*S(3)*B(-1)-12.96018889*S(3)-.4666666667*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-3)-.4666666667*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-2)-.4666666667*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-1)
2.748344167-.1820700000*S(3)*B(-3)-.1820700000*S(3)*B(-2)-.1820700000*S(3)*B(-1)-1.820700000*S(3)
17.25940667-.9805600000*S(3)*B(-3)-.9805600000*S(3)*B(-2)-.9805600000*S(3)*B(-1)-9.805600000*S(3)
-.2034933335+1.482334934*S(3)*B(-3)+1.482334934*S(3)*B(-2)+1.482334934*S(3)*B(-1)+14.82334934*S(3)-.3500000000*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-3)-.3500000000*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-2)-.3500000000*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-1)
44.36655818+.3921579862*S(3)*B(-3)+.3921579862*S(3)*B(-2)+.3921579862*S(3)*B(-1)+3.921579862*S(3)-.7291666668*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-3)-.7291666668*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-2)-.7291666668*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-1)
0.2185881458e-1-.1520195250*S(3)*B(-3)-.1520195250*S(3)*B(-2)-.1520195250*S(3)*B(-1)-1.520195250*S(3)
13.68262908-.2986166168*S(3)*B(-3)-.2986166168*S(3)*B(-2)-.2986166168*S(3)*B(-1)-2.986166168*S(3)-.1190000000*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-3)-.1190000000*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-2)-.1190000000*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-1)
50+(-22.06933333-1.4*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-3)-1.4*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-2)-1.4*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-1)+5.780693334*S(3)*B(-3)+5.780693334*S(3)*B(-2)+5.780693334*S(3)*B(-1)+57.80693334*S(3))*T(i)+(2.497813333-.4480000000*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-3)-.4480000000*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-2)-.4480000000*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-1)+1.849821867*S(3)*B(-3)+1.849821867*S(3)*B(-2)+1.849821867*S(3)*B(-1)+18.49821867*S(3))*T(i)^2+(-.9095153783-.4129066667*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-3)-.4129066667*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-2)-.4129066667*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-1)+1.704919154*S(3)*B(-3)+1.704919154*S(3)*B(-2)+1.704919154*S(3)*B(-1)+17.04919154*S(3))*T(i)^3
10+(28.43066667-1.4*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-3)-1.4*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-2)-1.4*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-1)+5.780693334*S(3)*B(-3)+5.780693334*S(3)*B(-2)+5.780693334*S(3)*B(-1)+57.80693334*S(3))*T(i)+(44.16516667-2.975000000*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-3)-2.975000000*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-2)-2.975000000*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-1)+12.28397333*S(3)*B(-3)+12.28397333*S(3)*B(-2)+12.28397333*S(3)*B(-1)+122.8397333*S(3))*T(i)^2+(52.09000233-1.296018889*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-3)-1.296018889*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-2)-1.296018889*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-1)+5.351348394*S(3)*B(-3)+5.351348394*S(3)*B(-2)+5.351348394*S(3)*B(-1)+53.51348394*S(3)-.4666666667*(-.9095153783-.4129066667*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-3)-.4129066667*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-2)-.4129066667*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-1)+1.704919154*S(3)*B(-3)+1.704919154*S(3)*B(-2)+1.704919154*S(3)*B(-1)+17.04919154*S(3))*B(-3)-.4666666667*(-.9095153783-.4129066667*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-3)-.4129066667*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-2)-.4129066667*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-1)+1.704919154*S(3)*B(-3)+1.704919154*S(3)*B(-2)+1.704919154*S(3)*B(-1)+17.04919154*S(3))*B(-2)-.4666666667*(-.9095153783-.4129066667*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-3)-.4129066667*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-2)-.4129066667*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-1)+1.704919154*S(3)*B(-3)+1.704919154*S(3)*B(-2)+1.704919154*S(3)*B(-1)+17.04919154*S(3))*B(-1))*T(i)^3
5+75.85*T(i)+(-21.81329000-1.071000000*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-3)-1.071000000*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-2)-1.071000000*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-1)+4.422230400*S(3)*B(-3)+4.422230400*S(3)*B(-2)+4.422230400*S(3)*B(-1)+44.22230400*S(3))*T(i)^2+(2.219127367-.1820700000*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-3)-.1820700000*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-2)-.1820700000*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-1)+.7517791681*S(3)*B(-3)+.7517791681*S(3)*B(-2)+.7517791681*S(3)*B(-1)+7.517791681*S(3))*T(i)^3
20+7.60*T(i)+(14.00564000-.7140000000*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-3)-.7140000000*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-2)-.7140000000*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-1)+2.948153600*S(3)*B(-3)+2.948153600*S(3)*B(-2)+2.948153600*S(3)*B(-1)+29.48153600*S(3))*T(i)^2+(14.40924560-.9805600000*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-3)-.9805600000*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-2)-.9805600000*(.2906666667-.4129066667*S(3)*B(-3)-.4129066667*S(3)*B(-2)-.4129066667*S(3)*B(-1)-4.129066667*S(3))*B(-1)+4.048797611*S(3)*B(-3)+4.048797611*S(3)*B(-2)+4.048797611*S(3)*B(-1)+40.48797611*S(3))*T(i)^3
Download badSums2.mw
Hello. It is required to find a solution of the boundary value problem by cubic b-spline collocation
We are looking for a solution in the form of a spline S(x). A cubic spline S(x) is represented as an expansion over normalized B-splines
Perhaps someone familiar with the method and can help implement the solution on Maple? I agree to any kind of cooperation. Really need help
Dears,
I have this file (of course it's not the real file):
input parameters
A := 5;
B := 6;
C := 7;
derived parameters
E := A*B;
F := cos(A)+e^B;
G := 265/C;
Parameters to be calculated
T := E^2+G-sin(F);
U := F+E-B;
I'd like to find a way for changing A, B, and C (for example giving them the values 1, 2, .. ,9) and getting a table (i mean a CSV or something else) with the values of T and U calculated for the different input values.
Do you know if it is possible?
And sorry if I wrote something wrong, it's my first post, and I'm not expert with Maple. I used it many years ago at the University, and now I'm trying to use it again.
I can type expression below:
s1 := sqrt(2);
                              (1/2)
map(op, indets(s1, sqrt));
                             /   1\
                            { 2, - }
                             \   2/
s2 := log[2](3);
                             ln(3)
                             ln(2)
map(op, indets(s2, ln));
And expression above is error
Error, type `ln` does not exist
Can you help me?
s3:=surd(2,3);
map(op, indets(s3, surd)); --> { }
s1 := sqrt(2)
2^(1/2)
{2, 1/2}
s2 := log[2](3)
ln(3)/ln(2)
map(op, indets(s2, log))
Error, type `log` does not exist
s3 := surd(2, 3)
2^(1/3)
Download help_map_indets.mw
I want to solve the equation (-2*cos(x)^2+2*sin(x+(1/4)*Pi)^2-1)/sqrt(-x^2+4*x) = 0 in RealDomain. I tried
RealDomain:-solve({(-2*cos(x)^2+2*sin(x+(1/4)*Pi)^2-1)/sqrt(-x^2+4*x) = 0}, {x});
I got four solutions
If I work around
 RealDomain:-solve({-x^2+4*x > 0, (-2*cos(x)^2+2*sin(x+(1/4)*Pi)^2-1)/sqrt(-x^2+4*x) = 0}, x);
I only got two solutions
With Mathematica, I got three solutions
That is mean, Maple lost the solution x = 5*Pi/4. I check this thing
f:= x-> (-2*cos(x)^2+2*sin(x+(1/4)*Pi)^2-1)/sqrt(4*x-x^2) ;
f(5*Pi/4);
and got the result 0.
Are these bugs?
I would like to find the optimal parameters of the attached optimal control problem
The system of ODEs is defined and boundary conditions and The hamilton Jacobi Bellman equations is written.
Optimal_control.mw
Many thinks
I'm currently working my thesis and can someone help me to write a code to solve this IVP
u_t + 2×u²×u_x−(u_x)²−½×u_{xx}×u=0
with initial condition
u(x,0)=-tanh(x)
Dear friends,
Greetings.
How to get the second solution.
how to change the guess value in maple.
figure 1 plot in Matlab with two different initial guesses.
TWOSOLUTION.mw
I am writing a maths books using maple now. It is fantastic to use maple for writing books in maths.
 in the polynomial x^3-3*x^2-33*x+35 This line is not copying in full line!!
Step 1: Find the sum of all the coefficients in the polynomial x^3-3*x^2-33*x+35 This line is copying in full!!
"= 1-3-33+35 = 0"
                                                 r x-1is a factor  ; 1 is a root of the polynomial.
In the next row, I copy pasted the lines above
"= 1-3-33+35 = 0"
Can any one find the reason?
Download cannotCopyWhy.mw
I enclose a part of my document where in I made a particular line with text and maths formats combined.Then I made changes in the line. Now copy paste does work only for the later half (both text and maths formats). The corrected first part is not being copied.
How do I do the corrections properly so that copy paste is not a problem at laer stages.
Thanks for the answer.
Ramakrishnan V
The equation sin(9*x-(1/3)*Pi) = sin(7*x-(1/3)*Pi) can be solved easy by hand with solutions k*Pi and -Pi/48 + K*Pi/8. With Maple, I tried
solve({sin(9*x-(1/3)*Pi) = sin(7*x-(1/3)*Pi)}, x, explicit, allsolutions)
I don't get the above solutions. How can I get these solutions?
My problem is related to recovering orbits from invariant polynomials, and their ideal of relations.
The invariant polynomials I obtained are:
u = x2 - x y + y2,
v = 2 x6 - 6 x5 y + 15 x4 y2 - 20 x3 y3 + 15 x2 y4 - 6 x y5 +  2 y6 ,
w = x6 - 4 x5 y + 10 x4 y2 - 10 x3 y3 + 5 x2 y4 - 2 x y5 + y6 .
Using the logic from the Cox et al. book I got that the algebraic relation (ideal of relations) between the invariants, which is:
11 u6 - 10 u3 v + 3 (v2 - v w + w2) = 0
Then, using Reduce[] (exact symbolic solver which uses cylindrical algebraic decomposition) from Mathematica I solved for x and y under the assumption x > y > 0, u > 0, v > 0 and w > 0, but I got rather a complex solution.
My question is whether there is a way to try getting something more straightforward than the solution given by Mathematica.
I tried to use Maple's solve function, but it immediately stops without any result of an error message.
My input for Reduce is:
Reduce[{x2 - x y + y2 == u, 2 x6 - 6 x5 y + 15 x4 y2 - 20 x3 y3 + 15 x2 y4 - 6 x y5 + 2 y6 == v,  x6 - 4 x5 y + 10 x4 y2 - 10 x3 y3 + 5 x2 y4 - 2 x y5 + y6 == w, 11 u6 - 10 u3 v + 3 (v2 - v w + w2) == 0, x > y > 0, u > 0, v > 0, w > 0}, {x, y}, Complexes]
and my input for solve:
solve({u = x^2 - x*y + y^2, v = 2*x^6 - 6*x^5*y + 15*x^4*y^2 - 20*x^3*y^3 + 15*x^2*y^4 - 6*x*y^5 + 2*y^6, w = x^6 - 4*x^5*y + 10*x^4*y^2 - 10*x^3*y^3 + 5*x^2*y^4 - 2*x*y^5 + y^6, 11*u^6 - 10*u^3*v + 3*v^2 - 3*v*w + 3*w^2 = 0, 0 < u, 0 < v, 0 < w, 0 < x, 0 < y, y < x}, {x, y})
Do you know what I am doing wrong, or what else could I try?
I use patmatch to look for certain expression inside a larger expression.
I find sometimes I need to repeat the same code to check for  "... + ..."   and also ".... * .....", since I do not know to tell Maple to look for + or * in the same code. *Luckily, I do not have to check for "-" or "/" operators, since "+" match with "-" and "*" match with "/").
An example will make things more clear.
Suppose I want to see if sin(x)*sqrt(x*y) has sqrt(x*y) anywhere in it. So I first try
expr:= sin(x)*sqrt(x*y);
if patmatch(expr,a::anything+(b::anything*x*y)^(c::anything),'la') then
    assign(la);
    if c =1/2 or c=-1/2 then
       print("found sqrt(x*y)");
       print("did not find sqrt(x*y)");
    fi;
 fi;
And this fails, since I used "+" inside the patmatch. Then I try '*" instead
if patmatch(expr,a::anything*(b::anything*x*y)^(c::anything),'la') then
And now it does match.
What I'd like to write, is something like this (which ofcourse does not work)
if patmatch(expr,a::anything (* or +) (b::anything*x*y)^(c::anything),'la') then
I looked at conditional in patmatch, but it does not seem to apply for the above.
Any suggestions?
Maple 2019.1 on windows 10
First 664 665 666 667 668 669 670 Last Page 666 of 2428
