I am sure that this is a common enough problem. I want to show what commands I'm using to make an output in a maple worksheet in a latex document that i can include in a report.
So far I've got the export feature to work:
(here is an example mapleworksheet, texfile and a corresponding LatexProducedPDF),
but i can't see how to get it to include the commands that create the output.
I have a list of relationships between variables, in this example there are three. The third of these requires at least one of the parameters to take a negative value i.e. kh[a1] = -kh[a2] how do I eliminate sets from a list like this that do that?
Sa1 := [{R = R, Rh = R, C[T] = Ch[T]*kh[a1]/k[a2], Ch[T] = Ch[T], k[a1] = kh[a2]*k[a2]/kh[a1], k[a2] = k[a2], k[d1] = k[d1], k[d2] = k[d2], kh[a1] = kh[a1], kh[a2] = kh[a2]}, {R = R, Rh = R, C[T] = C[T], Ch[T] = Ch[T], k[a1] = -(C[T]*k[a2]-Ch[T]*kh[a1]-Ch[T]*kh[a2])/C[T], k[a2] = k[a2], k[d1] = k[d1], k[d2] = k[d1], kh[a1] = kh[a1], kh[a2] = kh[a2]}, {R = R, Rh = Rh, C[T] = C[T], Ch[T] = Ch[T], k[a1] = -k[a2], k[a2] = k[a2], k[d1] = k[d1], k[d2] = k[d1], kh[a1] = -kh[a2], kh[a2] = kh[a2]}]
I want to use abstract linear operators between Lie algebras. I have the problem shown in the following short code:
with(LinearAlgebra): with(DifferentialGeometry): with(LieAlgebras):
LAr:=LieAlgebraData([ [e1,e2]=e3],[e1,e2,e3],LA);
DGsetup(LAr);
define(lin,linear);
lin(-e3);
lin(-LieBracket(e1,e2));
lin(LieBracket(e2,e1));
As you see, the minus "-" does not come out of the argument of lin() in the last line. What is going wrong?
Later on, I realized that the linear operator has nothing to do with the issue. The problem lies in the fact that the output of "LieBracket(e2,e1)" is "_DG([["vector", LA, []], [[[3], -1]]])" , where the latter "-1" refers to the coeffiecient. For some reason, this coefficient is not handled in the way I would expect. For example, the following two lines:
LieBracket(e2,e1)+LieBracket(e1,e2);
_DG([["vector", LA, []], [[[3], 1]]])+_DG([["vector", LA, []], [[[3], -1]]]);
give both as an output "e3+-e3" instead of "0", while both the lines
LieBracket(e2,e1) + LieBracket(e2,e1);
_DG([["vector", LA, []], [[[3], -1]]])+_DG([["vector", LA, []], [[[3], -1]]]);
give the output "2-e3" (which I interpret as "2(-e3)" ).
I don't understand what I am doing wrong.
I have PDE i trying to solve the equation using series.
pdsolve(diff(u(x, y), x, x)+diff(u(x, y), y, y) = Pi, series, order = 2);
Give me: "Error, (in DifferentialAlgebra:-RosenfeldGroebner) unexpected occurrence of the non-rational constants {Pi} in the given input" ?
pdsolve(diff(u(x, y), x, x)+diff(u(x, y), y, y) =gamma, series, order = 2);#gamma = 0.5772156649,Gives ERROR ?
If I  change instead of Pi is e or exp(1) works fine.
pdsolve(diff(u(x, y), x, x)+diff(u(x, y), y, y) = exp(1), series, order = 2);#OK.
It's a bug, design or  something else ?
Goodday sirs,
            How can I get over these error message123.mw
(int((1/6)*(eta-s)^3*(S*(s*f[i](s)+3*(diff(diff(f[i](s), s), s))+(diff(f[i](s), s))*(diff(diff(f[i](s), s), s))-f[i]*(diff(diff(diff(f[i](s), s), s), s)))+M^2*(diff(diff(f[i](s), s), s))), s = 0 .. eta))/(1+1/y)
G := (int((eta-s)^3*(S*(s*f[i](s)+3*(diff(f[i](s), `$`(s, 2)))+(diff(f[i](s), s))*(diff(f[i](s), `$`(s, 2)))-f[i]*(diff(f[i](s), `$`(s, 3))))+M^2*(diff(f[i](s), `$`(s, 2))))/factorial(3), s = 0 .. eta))/(1+1/y)
f[0] := (1/6)*s+(1/6)*s^3:
for i from 0 to n do f[i+1] := (1/6*(-eta^3+eta))*subs(eta = 1, diff(G, `$`(eta, 2)))-eta*subs(eta = G)+G; f[i+1] := subs(eta = s, f[i+1]) end do
Error, final value in for loop must be numeric or character
Anyone with useful informations please.
Thanking you in anticipation for a favurabke response
Download 123.mw
pde := [diff(u(x, y), x, x)+diff(u(x, y), y, y) = 2*Pi*(2*Pi*y^2-2*Pi*y-1)*exp(Pi*y*(1-y))*sin(Pi*x), u(0, y) = sin(Pi*y), u(1, y) = exp(Pi)*sin(Pi*y), u(x, 2) = exp(-2*Pi)*sin(Pi*x), u(x, 0) = u(x, 1)]pdsolve(pde)
pdsolve(pde)
it does not return any solution and answer, kindly help.
I have a vector field that has positive constants. I don't want to set perminant values for the constants becuase future calculations will be wrong.
Instead, how can I set a sample set of values for these constants? Thanks
Hi guys. I tried to find Killing Vectors for Taub-NUT metrics but the maple gives an error.  Can someone explain what is wrong?
How can one calculate isogeny of elliptic curves over finite fields in maple ?
Can't seem to get Retrieve from DocumentTools to get any labels from any worksheet.  I just get an error saying unable to retrieve label reference.
with(DocumentTools):
Retrieve("c:/test/test/mw","L1") #sample test file named test.mw in directory test
Here's the same issue (unanswered) way back in 2015 https://www.mapleprimes.com/questions/203811-DocumentTools-Retrieve-Function-Returns
Maybe it's a Windows administrator issue?  Does it work for anyone else?
u1 := proc (x, y) options operator, arrow; 1-e^(a*x)*cos(2*Pi*y) end proc;
a := -.39323780;
evalf(int(int(u1(x, y)^2, y = -.5 .. 1.5), x = -.5 .. 1.5));
             1             /                  /          5
  ------------------------ \0.000002034392421 \6.25000 10
         (5898567/5000000)
  ln(e) e
     (1966189/1250000)              6        (5898567/5000000)
    e                  + 1.966189 10  ln(e) e
                 5\\
     - 6.25000 10 //
I need help me , how can find this integral as simple number?
u1 := proc (x, y) options operator, arrow; 1-e^(a*x)*cos(2*`πy`) end proc;
u2 := proc (x, y) options operator, arrow; a*e^(a*x)*cos2*`πy` end proc;
norm(u2(x, y), 2)/norm(u1(x, y), 2);
Error, invalid input: norm expects its 1st argument, p, to be of type {Matrix, Vector, matrix, polynom, vector}, but received a*e^(a*x)*cos2*`πy`
Hi, I want to define A matrix (shown below) that has some definite products. These products have two arguments e.g. (k=1..N) and (k<>i) but product expects only one argument. What should I do?
I appreciate any help you can provide.
How to import and manipulate different formulas of  Excel files in maple ?
See example in attachment
Hi all
I wnat to produce following matrix P2r+1, 2r+1 in maple.
can any one help me please?
First 859 860 861 862 863 864 865 Last Page 861 of 2459
