  1. (k-2)*(k^2+5)*(k^3-k^2+7*k+8)/(6*k*(k^2-3*k+8))
  2. (k+2)*(k^2+5)*(k^3-5*k^2+13*k-8)/(6*k*(k^2-3*k+8))
  3. k^3+3*k^2+11*k-3
  4. k^2+2*k+9
How to draw the following function containing an imaginary number
u := proc (x, t) options operator, arrow; 1/2+I*sqrt(2)/(exp(x-t)+2*exp(-x+t))+(1/2)*(exp(x-t)-2*exp(-x+t))/(exp(x-t)+2*exp(-x+t)) end proc
Download plot33.mwDownload plot33.mw
I'm attempting to solve the complex-valued differential equation
assume(t::real):
pde := diff(A(t),t) - I * conjugate(A(t))*A(t)^2 = 0:
dsolve(pde);
However, it seems Maple attempts to solve it using separation of variables and gives
t-Intat(-I/conjugate(_a)/_a^2,_a = A(t))+_C1 = 0
Unless I'm mistaken, a complex integral such as this isn't even defined without a contour.
Working the integral out by hand, I know the solution to be
_C1*exp(I*abs(_C1)*t)
Is there a trick I'm missing to get Maple to find this solution? Or is this outside the scope of what Maple can handle on it's own?
I believe I am having memory issues which is causing the MAPLE kernal to terminate.  If I assign m a value then it seems to work, but I would like to leave m unassigned so that S1 can later be evaluated for any arbitrary m.  Is there a way around this?
T := M*tau;
`assuming`([simplify(expand(combine(S1)))], [m::integer])
Download MAPLE_crashing.mw
Hello everybody
I am currently having trouble 'manually simplifying' an equation that I differentiated using maple. Basically, the equation that I get involves hessian-matrices. Since the resulting equation is rather long, I would like to replace every such matrix by a sign, say H.
This is easy to do for non-matrix equations, i.e.
subs(sin(x)sin(y) = z, sin(x)sin(y) + xy)
will give me z + xy, which looks a bit easier.
However, I couldn't figure out how to do a similar thing with matrices. For example, the following code
subs(Matrix(3, 3, [[x, y, z], [y, z, x], [z, x, y]]) = A, Matrix(3, 3, [[x, y, z], [y, z, x], [z, x, y]])+B)
 will not work.
I already thought about converting the matrices first into lists (because for some reason it works for lists). However, I would also like to do the same as above for for functions of matrices, i.e. set F(A) = G, where A is a matrix (this also fails, probably for the same reason).
Also, the same thing seems to fail for vectors and general arrays, so I guess the actual problem might be the array type.
I also tried alternative ways, such as eval or algsubs, but the later even gives an error since it cannot handle matrices at all.
This feels a bit like a noob question, but I spent almost 2 days now searching for an answer or a workaround, so my apologies if I missed something trivial.
All the best
Adrian
Hi, I try to solve the below integral. when I press enter key maple dosen't show answer and show the integral again.
int(r*r[bc]*r[tc], r = r[bc] .. r[tc]);
but when I write intgral this way and use " i " as subscript ,maple solve it.
int(r[i]*r[bc]*r[tc], r[i] = r[bc] .. r[tc]);
I just want to know why?
what is difference between first and second integral?
and also is there any way (or any packages) to solve these integrals?
(I read https://www.maplesoft.com/applications/view.aspx?SID=6846&view=html article befor)
thanks.
Good day everyone,
I'm relatively new to Maple, and I study engineering (not maths), so maybe my problem is related to a bad approach of the equations.
The problem is that I'm asking Maple to do a double integral of a "complex" expression and it only solve the first integral, but not the second.
Here is the code:
https://www.dropbox.com/home/C%C3%81LCULO%20FUERZAS
Dears!
Hope everyone should be fine. I am face to import excel sheet in maple. I saved execl sheet with name "Employees.xlsx" at desktop. When I use the following command
S := Import("Employees.xlsx", 1, "A1:B101");
I got the following error.
"Error, (in ExcelTools:-Import) Could not open the file"
Please help me to fix this problem. I am waiting positive response.
Special request to:
@Carl Love
@Preben Alsholm
@acer
  1. (2*k^3-6*k^2+7*k+15-k*sqrt(k^6-12*k^5+64*k^4-198*k^3+448*k^2-636*k+369))/(-k^4+2*k^3-2*k^2+10*k+15)
  2. (k^3+5*k+(-k^2+k)*sqrt(k^4-10*k^3+37*k^2-60*k+180)+30)/(-k^4+k^3+k^2+5*k+30)
Please I am trying to get a compact result for this code in particular the lines assigne "a" and "b" respectively. I am sure the result shoud not be more than two lines. Can someone be of help?
P:=a[0]+(a[1]*x)/(1+(a[2]*x)/(1+(a[3]*x))):
Q:=diff(P,x):
T:=diff(P,x,x):
e1:=simplify(eval(P, x=q))=y[n]:
e2:=simplify(eval(Q,x=q))=f[n]:
e3:=simplify(eval(Q,x=q+h))=f[n+1]:
e4:=simplify(eval(T,x=q+h))=g[n+1]:
var:=seq(a[i], i=0..3):
M:=e||(1..4):
Cc:=eval(<var>, solve(eval({M}),{var}) ):
for i from 1 to 4 do
	a[i-1]:=Cc[i]:
Cf:=P:
a:=y[n+1]=collect(simplify(eval(Cf, x=q+h)),[y[n], f[n], f[n+1],g[n+1]], recursive):
b:=map(eval@allvalues, [a]);
I'm receiving a very interesting error when attempting to solve a system of differntial equations:
{sqrt(2)*sqrt(F1(t))*diff(F2(t),t) = 0}:
% union {F3(t) = 0}:
pdsolve(%, {F1(t),F2(t),F3(t)});
When attempting to run this code, I get the following error:
Error, (in pdsolve/sys) invalid input: DifferentialAlgebra:-DifferentialRing expects value for keyword parameter blocks to be of type {undefined, Or(list({name, unknown, list({name,unknown})}),name,unknown)}, but received [F3, F2, _F1 = (NULL), F1 = [_F1, F1], _F2]
Interestingly, removing the second line, or even the sqrt(2), allows the calculation to proceed correctly. It this a bug, or am I doing something wrong?
Thank you very much!
(I'm aware this would technically be a system of ODEs, not PDEs; my actual code includes additional partial derivatives. Additionally, dsolve appears to only generate a trivial solution in this case).
Hey folks.
I need to do a kind of loop calc. in maple and im not shure how to.
lets say i guess a temperature T.
i then put it through all soughts of eqations where the variabel T is necessary for the outcome of my result, which i then use again as T. the loop should finish when T as a result is the same as my guess in the beginning. like:
T:=45
bla bla calculation
T_new:= 35
again
T:=35
bla bla calculation
T_new= 35
Finish!!
Any ideas?
Dear sir I want to plot the graph for different values of F=0.1, F=0.2,F=0.5 . My codes are given and i am attaching the sample graph. For F=0.1, Nb=0.1,0.2,0.3 three curves
Similarly For F=0.2,Nb=0.1,0.2,0.3 three curves and for F=0.5, Nb=0.1,0.2,0.3 three curves. Total nine curves
h:=z->1-(delta2/2)*(1 + cos(2*(Pi/L1)*(z - d1 - L1))):
K1:=((4/h(z)^4)-(sin(alpha)/F)-h(z)^2+Nb*h(z)^4):
lambda:=Int(K1,z=0..1):
L1:=0.2:
d1:=0.2:
alpha:=Pi/6:
plot( [seq(eval(lambda, Nb=j), j in [0.1,0.2,0.3])], delta2=0.02..0.1);
please how can I simplify the results of assigned K cum each of the coefficients further in the following code? the results are too large.
#k=2:
omega:=u/h:
psi:=v/h:
t:=(sum(a[j]*x^j,j=0..2)+a[3]*sin(omega*x)+a[4]*cos(omega*x)+a[5]*sin(psi*x)+a[6]*cos(psi*x)):
F:=diff(t,x):
G:=diff(t,x,x):
p1:=simplify(eval(t,x=q+h))=y[n+1]:
p2:=simplify(eval(F,x=q))=f[n]:
p3:=simplify(eval(F,x=q+h))=f[n+1]:
p4:=simplify(eval(F,x=q+2*h))=f[n+2]:
p5:=simplify(eval(G,x=q))=g[n]:
p6:=simplify(eval(G,x=q+h))=g[n+1]:
p7:=simplify(eval(G,x=q+2*h))=g[n+2]:
vars:= seq(a[i],i=0..6):
Cc:=eval(<vars>, solve({p||(1..7)}, {vars})):
for i from 1 to 7 do
	a[i-1]:=Cc[i]:
Cf:=t:
K:= collect(combine(simplify(eval(Cf,x=q+2*h),size),trig),{y[n+1],f[n],f[n+1],f[n+2],g[n],g[n+1],g[n+2]},factor):
alpha[1]=simplify(coeff(K,y[n+1]));
beta[0]=simplify(coeff(K,f[n]),size);
beta[1]=simplify(coeff(K,f[n+1]),size):
beta[2]=simplify(coeff(K,f[n+2]),size):
gamma[0]=simplify(coeff(K,g[n]),size):
gamma[1]=simplify(coeff(K,g[n+1]),size):
gamma[2]=simplify(coeff(K,g[n+2]),size):
I need to plot a trajectory where the horizontal equation is x(t) = 4t and the vertical is y(t)=4t-0.5t^2
How would I plot the two equations at once to make a trajectory?
If someone could please explain how to do it (also doing it would be nice) because I'm sure I'll have to do it again.
First 895 896 897 898 899 900 901 Last Page 897 of 2459
