Hi guys ,
Actually i dont know how to solve the following complicated differential equations by numerical methods ,
numerical.mw
Thank you for your attention to this matter
Can we sketch a Simulink model using Maple.
Dear friend,
please suggest a way for manipulation of derivative of a function symbolically. Assume
Typesetting[Suppress]([f(x)]);
Ex1 :=expand(diff(f(x+y)+x*f(x-y), x)^2)+expand(diff(f(x-y)-y*f(x+y), x)^2);
Result is as needed:
Ex1 := (D(f))(x+y)^2+2*(D(f))(x+y)*f(x-y)+2*(D(f))(x+y)*x*(D(f))(x-y)+f(x-y)^2+2*f(x-y)*x*(D(f))(x-y)+x^2*(D(f))(x-y)^2+(D(f))(x-y)^2-2*(D(f))(x-y)*y*(D(f))(x+y)+y^2*(D(f))(x+y)^2
But later I cannot use D(f) as a function. Expressions
subs((D(f)) = (t -> 1-t), Ex1);
subs(diff(f(x),x) = (t -> 1-t), Ex1);
do not handle it as a function.
Maple 16 code
N1 := FileTools[Text][CountLines](g)
I encounter an error message
in FileTools:-Text:-CountLines) permission denied
What  went wrong ?  This never happened before
I  re install  Maple 16, the same error persists.
Please help
Martin
I am trying Maple 2017 pdsolve for heat PDE in 1D. It seems Maple can solve now  heat PDE with homogeneous dirichlet boundary conditions (good). But when I set the boundary conditions to homogeneous neumann B.C. instead, I get an answer when this B.C. is prescribed to the left side. When this B.C. is on the right side, I get an error. Which is strange.
I am newbie in Maple, so may be I am doing something wrong in the syntax?  In addition, the answer I get when homogeneous neumann B.C. is on the left side, does not match my hand solution, which I know is correct. I'll show this below.
First, here is the case where it works. homogeneous dirichlet boundary conditions on both sides:
pde:=diff(u(x,t),t)=k*diff(u(x,t),x$2);
bc:=u(0,t)=0,u(L,t)=0;
sol:=pdsolve([pde,bc]) assuming 0<L:
This answer is correct. Now when setting the right side to homogeneous neumann B.C. I get an error
bc:=u(0,t)=0,D[1](u)(L,t)=0;
pdsolve([pde,bc]) assuming 0<L;
I think may be it does not like `L` there in the B.C. But how else to tell it this B.C.? The above is the only syntax I know. And finally, when using homogeneous neumann B.C. on the left side, I get this result
bc:=D[1](u)(0,t)=0,u(L,t)=0;
The correct answer for this B.C. is
The answer should be series solution as well with eigenvalues. I think if I expand Maple solution in series may be I will get it to match my hand solution. I need to look at this more later.
my question is: Why do I get an error when homogeneous neumann B.C. is on the right side but not on the left side?
I suspect I am not entering the B.C. correctly? If so, How does one enter homogeneous neumann B.C. for this 1D heat PDE?
how can I sort a diff EQ by its degree.  Example 4th order with 4 being farthest left in normal reading format?
D4 + D3 + D2 +D + C = F(t)
my equation display is currently:
C + D + D2.......
Bill
I'm not quite sure how I should put this and the title might be a bit misleading. Basicly when I use variables which I have defined with a value I would like for the equation to be shown with the values of the variables before the results. Not sure if that made sense so I made this picture.
Basicly when I write as in line (1) it just gives me the result, which is fine but I'd like it converted too if that makes any sense as in line (2). I made line (2) myself (just changed the colour of standard mathtype). I'd like the calculations to be shown as in line (2) where first you see the formula: lambda=v/f, then it inserts the values of the variables and finally calculates this. Is there any way to do this?
I couldn't really find anything in the manual or using google.
Regards, Simon
  Assume that one has an equation P(a,b,c,d,e,f)=0. How do we solve this equation so that the parameters b and c are in terms of a, and the parameters d and e in terms of f?
hello . how can i get 7 given parameters(b1,a1,b1,a2,b2,.....) in this equation with maple. thanks
1.mw
Imagine we have an ODE system
odeSys := {diff(x(t),t$2)+diff(x(t),t)+x(t)=f(t),diff(y(t),t$2)+2*diff(y(t),t)+3*y(t)=g(t)};
It is easy to transform this system into a first order form by hand. But for larger systems, the procedure by hand becomes very error prone. Is there an intelligent way to transform a system of n scalar ODEs (order m) into a first order system? I know that the first order form is not unique. It is only important to reduce the system to a system of first order equations.
this forum has helped me a lot since I'm quite new at maple. There are lot of questions about the solution of _Z in roots but I still can't figure it out.
Here my problem:
f(x,y)= x*y - (V^(alpha)*W)/(V-a*x-b*y)^alpha
x>0, y>0, a>0, b>0, alpha>0, V>0, W>0, V-a*x-b*y>0
I need to find the maximum values for x and y. But all the solutions have got _Z.
How can I eliminate _Z? Thanks!
Best regards,
Won
I am learning pdsolve in Maple. When I try to solve a diffusion pde, I get this strange error message, and I do not understand what it means: This is using Maple 2017 on windows 7
bc:=f(t,0)=0,f(t,1)=1;
ic:=f(0,x)=piecewise(x=0,1,0);
pde:=diff(f(t,x),t)=diff(f(t,x),x$2);
pdsolve({pde,bc,ic},f(t,x));
The error is
Error, (in casesplit/K) this version of casesplit is not yet handling the function: piecewise
Am I writing the initial conditions (ic) wrong?  Maple help shows nothing on this. I think Maple does not like my initial conditions. But do not know how to correct it now.
What causes this error?
Hello.
I am asked to find all the candidate points to absolute maximum or minimum in a domain delimited by several lines or curves.
Let me show you an example:
I am having trouble trying to find the candidate points on the boundary of the domain with LagrangeMultipliers.
How should I express the line or curve equations so that I can use them as constraints of LagrangeMultipliers? Should I use another method?
Thanks a lot.
That the Bernoulli numbers has z/(exp(z)-1)) as an exponentional generating functions is of course very well known. I am wondering why the gfun package doesn't seem to be able to work this out? Naive approaches like
gfun[guessgf]([seq(bernoulli(n),n=0..100)],z);
give FAIL. I would expect gfun to be able to transform the given sequence corresponding to replacing A(z) by 1/A(z), easily recognize (exp(z)-1))/z, and transform back. Perhaps the package is in need of maintenance?
Any help would be much appreciated.
Best,
Soren
I want to solve a system of algebraic equations in maple using as follows:
equations:={b[1](2)*a[1](2, 1) = 1/2, b[1](2)*a[1](2, 1)^2 = 1/3, b[1](2)*a[2](2, 1) = 1/2, b[1](2)*a[2](2, 1)^2 = 1/3, b[2](2)*a[1](2, 1) = 1/2, b[2](2)*a[2](2, 1) = 1/2, b[1](2)*(a[3](2, 1)+a[3](2, 2))*a[1](2, 1) = 1/3, b[1](2)*(a[3](2, 1)+a[3](2, 2))*a[2](2, 1) = 1/3, b[1](2)*a[2](2, 1)*a[1](2, 1) = 1/3, b[1](1)*(a[3](1, 1)+a[3](1, 2))+b[1](2)*(a[3](2, 1)+a[3](2, 2)) = 1/2, b[1](1)*(a[3](1, 1)+a[3](1, 2))^2+b[1](2)*(a[3](2, 1)+a[3](2, 2))^2 = 1/3, b[2](1)*(a[3](1, 1)+a[3](1, 2))+b[2](2)*(a[3](2, 1)+a[3](2, 2)) = 1/2, b[1](1)+b[1](2) = 1, b[2](1)+b[2](2) = 1}
variables:={a[1](2, 1), a[2](2, 1), a[3](1, 1), a[3](1, 2), a[3](2, 1), a[3](2, 2), b[1](1), b[1](2), b[2](1), b[2](2), b[3](1), b[3](2)}
solve(equations,variables);
But I get an error mesage that the equations is not valid equation or expression.
Any help?
First 978 979 980 981 982 983 984 Last Page 980 of 2434
