Question: Trailing Stop Loss Distribution
I have done a lot of research and simulation when it comes to trailing stop losses.
I have managed to get very nice results but only through theoretical reasoning
and simulation. However simulation is not as "pure" as manipulating equations.
What I have not managed to do so far is to manipulate the PDF to get an probability
that the trail stop is going to be triggered for a specified normal distribution (mean, volatility)
and trailing distance.
I would assume the problem could be solved by using conditional probabilities.
The intuition is that if we for example set the stop at -10 then we only allow the return to drop -10
for the last n days if it drops more than that the return becomes zero. From a simulation
perspective the price is only allowed to drop -10 from the highest point. The conclusion
is always the same that the expected return remains positive over time and I can prove
this by using a binomial tree but I want to find some elegant mathematical way to
explain this by using conditional density functions.   Any ideas ?!
