Question: confidence limit of Poisson Distribution
P := proc (x, lambda) options operator, arrow; piecewise(x < 0, 0, lambda^x*exp(-lambda)/factorial(x)) end proc;
The upper confidence limit. When the confidence limit is 95%, e is 0.05
Lu := proc (a) options operator, arrow; sum(P(x, lambda), x = 0 .. a) = 0.5e-1 end proc
Lu(10)
exp(-lambda)+lambda*exp(-lambda)+(1/2)*lambda^2*exp(-lambda)+(1/6)*lambda^3*exp(-lambda)+(1/24)*lambda^4*exp(-lambda)+(1/120)*lambda^5*exp(-lambda)+(1/720)*lambda^6*exp(-lambda)+(1/5040)*lambda^7*exp(-lambda)+(1/40320)*lambda^8*exp(-lambda)+(1/362880)*lambda^9*exp(-lambda)+(1/3628800)*lambda^10*exp(-lambda) = 0.5e-1
`assuming`([solve(Lu(10), lambda, useassumptions)], [lambda > 0])
No solition. ?
The lower confidence limit
Ll := proc (a) options operator, arrow; sum(P(x, lambda), x = a .. infinity) = 0.5e-1 end proc
Ll(10)
(1/362880)*(362880*exp(lambda)-362880-362880*lambda-181440*lambda^2-60480*lambda^3-15120*lambda^4-3024*lambda^5-504*lambda^6-72*lambda^7-9*lambda^8-lambda^9)/exp(lambda) = 0.5e-1
 RealDomain:-solve((1/362880)*(362880*RealDomain:-exp(lambda)-362880-362880*lambda-181440*RealDomain:-`^`(lambda, 2)-60480*RealDomain:-`^`(lambda, 3)-15120*RealDomain:-`^`(lambda, 4)-3024*RealDomain:-`^`(lambda, 5)-504*RealDomain:-`^`(lambda, 6)-72*RealDomain:-`^`(lambda, 7)-9*RealDomain:-`^`(lambda, 8)-RealDomain:-`^`(lambda, 9))/RealDomain:-exp(lambda) = 0.5e-1, lambda);
                          -2.635610964
Lambda should be positive.
Can be solved using the package Statistcs?
Gracias
 Poisson
