Question: Tables as datatype for efficient maple code
Hi all,
I wonder if it makes sense to use tables as datatype for efficient maple code. I need this datatype to pass parameters to a procedure which is called many times.
In particular, I have the following criteria:
* efficient (fast) to access for read and write.
* potentially thread save ( I can also imagine having individual copies for each thread)
* present in future Maple versions
* easy to transform into C-code later
I am thinking of something similar to structures in C which I can imagine to realize with tables:
mytable['field1']:=1;
mytable['field2']:=2;
myprocedure:=proc(tab::table)
  result:=Pi*tab['field1']+tab['field2'];
which is similar to
mytable->field1=1;
mytable->field2=2;
double myprocedure(struct table *tab)
 double result;
  result=Pi*tab->field1+tab->field2;
As structures the datatype should allow for fields of various type. But are tables efficient enough for this task or can I run into problems?
Thanks in advance!
