Question: Solving non-linear coupled initial value problem
I am trying to solve three non-linear coupled initial value problems. The equations are a bit complicated. The MAPLE code is
with*plots
eq[1] := (1/6)*Ra*v(x)^3*((2*v(x)*w(x)^2*(v(x)^2/w(x)^2-3)*(diff(w(x), x))-6*w(x)^3*(1-v(x)/w(x))^2*(diff(v(x), x)))*A+v(x)^2*w(x)^2*(2*v(x)/w(x)-3)*(diff(w(x), x))-3*w(x)^4*(1-v(x)/w(x))^2*(diff(v(x), x)))/(w(x)^2*(w(x)+2*A)^2*(2*v(x)+3*B))+u(x)
eq[2] := (1/105)*(diff(u(x)^2*(v(x)^2+11*B*v(x)+39*B^2)/v(x), x))+(1/6)*Ra*Pr*v(x)*((3*v(x)*w(x)^2*(v(x)^2/w(x)^2-2)*(diff(w(x), x))-12*w(x)^3*(1-v(x)/w(x))^2*(diff(v(x), x)))*A+v(x)^2*w(x)^2*(3*v(x)/w(x)-4)*(diff(w(x), x))-6*w(x)^4*(1-v(x)/w(x))^2*(diff(v(x), x)))/(w(x)^2*(w(x)+2*A)^2)-Pr*u(x)/v(x)
eq[3] := (1/60)*(diff(u(x)*w(x)^2*(v(x)*w(x)^3-4*v(x)^2*w(x)^2+5*v(x)^3*w(x)+(2*w(x)^3-6*v(x)*w(x)^2+20*v(x)^3)*B)/(v(x)^4*(w(x)+2*A)), x))-2/(w(x)+2*A)
pars := {A = 1, B = 1, Pr = .7, Ra = 100}
for i to 3 do Eq[i] := subs(pars, eq[i]) end do
eqs := Eq[1], Eq[2], Eq[3]
ICs := u(0) = 0, v(0) = 0, w(0) = 0
vars := u(x), v(x), w(x)
sol := dsolve({ICs, eqs}, {vars}, type = numeric)
sol(.1)
MAPLE says:
Error, (in sol) cannot evaluate the solution past the initial point, problem may be complex, initially singular or improperly set up
Is it possible to solve the problem in MAPLE? If yes, then how do I approach?
Thanks,
Subho
