Question: logplot of data fails
I have 2 column vectors I am trying to plot against each other. The vertical axis needs to be logarithmic.
If I say
plot(mass,map(log,pressure),style=point);
it works and I get all 19 points.
If I say
logplot(mass,pressure);
I get the correct scales in both directions (so nothing would be cut-off) but it plots only 4 points.The same happens if I use plot(...,axis[2]=[mode=log]);
The pressure values range from 1E-7 to 1E-12. It seems that nothing below 1E-8 (on the Y axis) is plotted. The 4 points that are plotted are plotted correctly. Again, the vertical scale reaches down to 1e-13 so it is not a scale/cut-off issue.
What gives???
Maple 15 on Mac OS X 10.4 PPC.
Mac Dude
