Question: `evalf/int`, "external hardware float library could not be found/used"
After first tests with my brandnew Maple 16 (64bit) installation on Ubuntu Linux (12.04 Ubuntu Precise) I encountered the following error:
when I run e.g.
     evalf(Int(BesselJ(3,x),x=1..13,digits = 4,method = _d01ajc));
with OpenMaple
I wonder how to fix it.
I have
    export MAPLE=...
and
    export LD_LIBRARY_PATH=...
which used to be sufficient for my maple code with previous maple versions.
Do I need to set further environment variables? Note that the same command works if I use commandline maple!
Thanks in advance!
