Question: Problem reading a file
Hello all
I have a worksheet where I use a .txt file as input (link in the end). Then, if I try the following command
bettermcproc(10,2*10^5,10^(-6),-60);
it fails, saying it cannot calculate. If, however, instead of using the input file I put it all in the worksheet it works perfectly. I know I could just put it all in the worksheet, but I want to save some space and time, since I use the same input file to do lots of different things.
Thank you all for the help
