Question: How to write the equation of the plane passing through three points satisfies the given conditions?
I want to write the equation of the plane passing through the three points A, B, C has the form ax + by + cz + d = 0 where a, b, c, d are integer numbers, a >0 if a <> 0; b>0 if a = 0 and b<>0,...and igcd(a, b, c) = 1.
If the coordinates of the vertices A, B, C are all integers, for example A(2,2,2), B(1,2, -1), C(1,-1,-4), I tried,
with(geom3d):
point(A,2,2,2):
point(B,1,2, -1):
point(C,1,-1,-4):
plane(P,[A,B,C],[x,y,z]):
n:=NormalVector(P);
k:=igcd(n[1],n[2],n[3]):
if n[1]<>0 then
sign(n[1])*1/k*sort(Equation(P))
elif n[2] <> 0 then sign(n[2])*1/k*sort(Equation(P))
else sign(n[3])*1/k*sort(Equation(P))
end;
If the coordinates of the vertices A, B, C are rational numbers, for exmaple, point(A,-2,-1/7, 5/3), point(B,1/8, -2, -1), point(C,1,-1,4). How do I tell Maple to do that?
