Question: Assigning points on a plot [i,j] values
I have a plot of a cylinder with points singled out.
Firstly, the points are currently given by (x,y,z) but I would like them in terms of (r,θ,z), how can I do this?
Secondly, I was wondering how to assign to each point an [i,j] value? So you could have r[i,j], θ[i,j] and z[i,j] as matrices of the points?
Points_on_the_initia.mwPoints_on_the_initia.mwPoints_on_the_initia.mw
with(plots)
with(plottools); plots[interactive]; with(ArrayTools)
PP := polarplot([2, theta, theta = 0 .. 2*Pi], scaling = constrained, numpoints = 50); PP
slices := [seq(polarplot([2, theta, theta = 0 .. 2*Pi], numpoints = 50), z = 0 .. 2, .1)]
slices[10]
op(slices[10]); CURVES(Vector(4, {1 = ` 1..143 x 1..2 `*Array, 2 = `Data Type: `*float[8], 3 = `Storage: `*rectangular, 4 = `Order: `*C_order}), Vector(4, {1 = ` 1..33 x 1..2 `*Array, 2 = `Data Type: `*float[8], 3 = `Storage:  `*rectangular, 4 = `Order: `*C_order}), Vector(4, {1 = ` 1..33 x 1..2 `*Array, 2 = `Data Type: `*float[8], 3 = `Storage:  `*rectangular, 4 = `Order: `*C_order}), COLOUR(RGB, 1., 0., 0.)), AXESLABELS(x, y)
a := op([1, 1], slices[10])
pointplot(convert(a, listlist))
data := Array(1 .. 1, 1 .. 3); Matrix(1, 3, {(1, 1) = 0, (1, 2) = 0, (1, 3) = 0})
for j to nops(slices) do if nops(op(1, slices[j])) > 1 then data := Concatenate(1, data, seq(Concatenate(2, op([1, k], slices[j]), Vector[column]([seq(-.1+.1*j, s = 1 .. op(2, Dimensions(op([1, k], slices[j]))[1]))])), k = 1 .. nops(op(1, slices[j]))-1)) end if end do; data; Vector(4, {1 = ` 1342 x 3 `*Matrix, 2 = `Data Type: `*anything, 3 = `Storage: `*rectangular, 4 = `Order: `*Fortran_order})
points := pointplot3d(data, axes = framed, colour = black)``
points
getdata(points)
ThePoints := convert(data, list, nested = true)
T2 := [seq(ThePoints[i], i = 2 .. 51)]``
BC1 := pointplot3d(T2, axes = framed, colour = black)
BC1
T3 := [seq(ThePoints[i], i = 1002 .. 1051)]
BC2 := pointplot3d(T3, axes = framed, colour = black)
BC2
cylinderpic := plot3d(2, theta = 0 .. 2*Pi, z = 0 .. 2, coords = cylindrical, axes = framed, color = white, transparency = .75); cylinderpic
T := [seq(ThePoints[i], i = 52 .. 1001)]NULL
Nodes := pointplot3d(T, axes = framed, colour = cyan)
Nodes
display(BC1, BC2, cylinderpic, Nodes)
Download Points_on_the_initia.mw
I've uploaded the file that gives all of the points!
Thank you :)
Rach
