Question: Integro-differential equation and help solving a system
Hi everyone
It's been a while since I last used Maple, so maybe these are simple questions
The first is:
I have a DE
eqbz:=diff(y(x),x)=-l/x^2*(y(x)^2-yeq(x)^2)
yeq(x) is a simple function of x and I want to solve it with "l" as a parameter and ic:=y(0.01)=1
sol:=dsolve({eqbz,ic},numeric,output=listprocedure,range=0.01..10^3,parameters=[l])
then I proceed to plot
ysol:=eval(y(x),sol)
ysol(parameters=[l=x]):
current:=convert(ysol(parameters,`global`):
loglogplot(ysol(x),x=1..100);
This works until l=10^6 or so, when it doesnt plot anymore. Now, I know that there's a solution for higher values of "l" (asked a friend to try on mathematica 8). How to solve this?
The other question is, when I try to use yeq(x) as an integral on a variable different than x
yeq:=x^3*evalf(Int(p^2/(exp(x*sqrt(p^2+1))+1),p=0.001..10^5))
with the same dsolve, I get an error saying there's an extra non-specified variable {p}
I tried to set yeq as a procedure
yeq:=proc(x)
local p
and use dsolve(..., known=yeq) but I get the same error. I had another system where I did it differently:
ydef:=yeq(x)=evalf(Int...))
sys:=subs(ydef,eqbz)
dsolve(sys,...)
again it doesn't work. Any suggestions?
