Question: Solving ODE with moving boundary conditions
I am trying to solve a nonlinear second order ODE with a parameter to be determined. I can set up most of the problem but I am having trouble trying to tell the computer the following boundary condition,
diff(f(x),x) = -K on f(x)=0.
(K will be inputted and is not to be solved for) As i said before, the other boundary conditions are fine and the numerical solution works if i use different boundary conditions.
For other boundary conditions (for example df/dx = 0 at x=0) I write in the form
D(f)(0)=0
I hope this makes sense and someone has a solution. Thanks in advance.
Matt
