Question: Numerical Method
Write a Maple procedure that solves for y(1) in the initial value problem
                     y′ = f(y),     y(0) = 1,
using a numerical stencil based on the nth order Taylor series expansion of y. The procedure’s arguments should include an arbitrary function f, an integer n representing the accuracy of the Taylor series expansion, another integer N representing the number of steps between x = 0 and x = 1. Pick a test problem and compare your results with the output of dsolve/numeric.
