Question: pdsolve for 2D Laplace's equation
I'm trying to analytically solve for a Laplace's equation in a unit square with the following BCs: u(x,0) = 0, u(y,0) = 0, u(1,y) = 0, u(x,1) = 1
The series solution to this problem is well-known, where u(x,y) is solved with separation of variables to obtain u in terms of sin and sinh series.
I try to recreate the solution with pdsolve but am stuck with it.
My attempt:
lap2d := diff(u(x,y), x, x) + diff(u(x,y), y, y) = 0
sol := pdsolve(lap2d, HINT = X(x)*Y(y), build)  % saw this in mapleprimes
With this I managed to get an expression for u(x,y). My trouble is with the coefficients: _C1, _C2, _C3, _C4, _c_1
_C1 .. _C4 are clearly from integrations, but I am not clear about _c_1?
To solve for the constants of integrations, I tried to set up simultaneuous equations with the BCs.
For example,
eq1 := eval( rhs(sol), x=0) = 0
Similarly, repeat for the other 3 BCs to get eq2, eq3, eq4
I tried to solve these simultaneous eqns with:
solve({eq1, eq2, eq3, eq4}, {_C1, _C2, _C3, _C4})
but Maple does not output anyting.
Need your advice if this is the right way and I just goofed up with the syntax, or there are better ways to construct the series solution of the problem. Should I use linearsolve to find the C's?
I use Maple 17.
Thanks in advance
