Question: Problem with Maple 18.01 exporting Code Edit Region
When greek symbols are used in code edit region (by copying from worksheet 2d math mode), they used to get exported properly to PDF but the only issue was large code edit region used to get cut off. But now with this new 18.01 update, code edit region is not cut off but greek symbol inside code edit region are not appearing in PDF export instead just pink boxes. Has anyone else also encountered this issue and suggest a resolution.
