Question: Export to file calculated parameters
I have some variables which usually have a specific value. I also have some parameters which are calculated using the previously mentioned constants. Sometimes though I want to change the value of the constants and re-calculate the parameters. Therefore I created a library with the initial values of the constants which I load inside a procedure which calculates the parameters. That way I can change the value of the constants and the initial values are not overwritten. My problem is that I want to export the calculated parameters and the value of the constants at the specific calculation. How do I do that_ I don't have an array, table or anything like that. Should I put my parameters in a table?
Thank you for your time.
