Question: how to create table like output for displaying lists of numbers or any data
If I want to make a display of data, say 2 columns of data, with a heading on top of each column, how would one go about this in Maple? This will be for display purposes only (say for final result of a homework result, etc..)
In Mathematica, I use the Grid command. I am not sure how to do this in Maple. I could not find Grid like command in Maple.
I can generate the data in 2 sequences  in Maple, but need to insert a heading, and also need to insert frame around eveything.
Here is an example:
f:=x->x^2;
g:=x->x^3;
data=[seq([i,f(i),g(i)],i=0..5)];
    #data = [[0, 0, 0], [1, 1, 1], [2, 4, 8], [3, 9, 27], [4, 16, 64], [5, 25, 125]]
The above data has 3 columns, 6 rows. I need to insert first row also called {"index","f","g"} and then display all in nice table form. This is how I would do the above in Mathematica to give idea of what I looking for
f[x_] := x^2;
g[x_] := x^3;
data = Table[{i, f[i], g[i]}, {i, 0, 5}]
    (* {{0, 0, 0}, {1, 1, 1}, {2, 4, 8}, {3, 9, 27}, {4, 16, 64}, {5, 25, 125}} *)
And this is below the part I do not know how to emulate in Maple:
data = Insert[data, {"i", "f(i)", "g(i)"}, 1]
    #   {{"i", "f(i)", "g(i)"}, {0, 0, 0}, {1, 1, 1}, {2, 4, 8}, {3, 9, 27}, {4, 16, 64}, {5, 25, 125}}
    # now use Grid to format with frame around everything
Grid[data, Frame -> All]
