Question: how to determine the nature of an equilibrium point using eigen values
If I have the following system of first order diff eq's:
x'(t)=2x(t)+3y(t)
y(t)=-3x(t)-2y(t)
then can I consider the coefficient matrix A=<<2,-3>,<3,-2>> and compute the eigenvalues of A and infer as follows:
if the eigenvalues are of the same sign- eq point is a node
if they are of opposite signs- eq point is a saddle
if they are pure imaginary- eq point is a center
if they are complex conjugates- eq. point is a spiral
I've been given these conditions but my text says for a linear system of the form x'=Ax, the eigenvalues of A can be used to identify the nature of the eq. point. I am confused as to whether this applies to the given system as well; I have obtained 5 different trajectories and drawn the phase diagram for the system
