Question: procedure "proc"
Question:procedure "proc"
Alger 519 Maple
Dear all,
I have one probem in using Maple in comparison with Matlab.
Generally, when using Matlab, I write a long program with 500 lines (for example) and where I use some matricial calculations and other. When I want to repeat this program for some parameters (variables) many times, I transform the program to a procedure "Function" with just adding the command Function in the start of the program.
When using Maple, I have a difficulty to transform a long program which I want to repeat for some variables to a procedure "proc". The program uses packages like LinearAlgebra and other procedures.
Is there a simple way to transform a long Maple program to a procedure which should be repeated many times for some variables in Maple.
I have especially problems with the commands local, global, use (for packages), etc.. and the warning related to the variables. It is not easy for a long program with many variables to write them in local or global variables.
Thank you.
