Question: Set of polynomials with certain property?
How can I compute F from G according to the following text? (I implemented this but I need a more efficient implementation.)
Given a set G of polynomials which are a subset of k[U, X] and a monomial order with U << X, we want to comput set F from G s.t.
1. F is subset of G and for any two distinct f1, f2 in F , neither lpp (f1) is a multiple of lpp (f2) nor lpp (f2) is a multiple of lpp (f1).
2. for every polynomial g in G, there is some polynomial f in F such that lpp (g) is a multiple of
lpp (f ), i.e. ⟨lpp (F )⟩ = ⟨lpp (G)⟩,
It is worth nothing that F is not unique.
Example:  Let us consider G = {ax^2 − y, ay^2 − 1, ax − 1, (a + 1)x − y, (a + 1)y − a} ⊂ Q[a, x, y], with the lexicographic order on terms with a < y < x.
Then F = {ax − 1, (a + 1)y − a} and F ′ = {(a + 1)x − y, (a + 1)y − a} are both considered set.
please not that K[U,X] is a parametric polynomial ring (U is e sequence of parameters and X is a sequence of variables).
lpp(f) is leading monomial of f w.r.t. variables X. For example lpp(a*x^2+b*y)= x^2.
