Question: Simplification question
I have a polynomial expression that I would like to cast into a specific form. The expression is
and I know that it can be simplified into a form involving squares of (A[Qi]-Pi). It is trivial to do this on paper; how can I convince Maple to do this.
The solution I came up with was to use mtaylor and expand about the forms I know to be there:
mtaylor((3),[A[Q1]=P1,A[0]=P2*rho/(rho+Q1),A[Q3]=P3],6);
which is what I want (close to, anyway). Now, I consider this to be a bit of a dirty trick that works here as the expression is simple and no higher-order terms are present so in fact the solution is exact. But, are there methods along simplify and friends that can do this? I have not been successfull with those...
This is a part of a much longer worksheet and part of a lecture, so I need Maple to be able to do this. The mtaylor trick works, but I would not want to miss an obvious approach that may work where mtaylor would get confused.
Thanks,
M.D.
test.mw
