Question: Comparison of element-wise operators and map function
I have just discovered the existence of element-wise operators which uses the symbol tilde
In the help, I saw this exemple
sin~(<1,2,3>);
Vector[column](%id = 18446744073926346622)
which is identic to a result that I can find with map function :
map(sin,<1,2,3>);
Vector[column](%id = 18446744073926346982)
What can Element-wise operators bring more than the map function ?
Do you often use this symbol ?
Thanks a lot for your information.
