Question: Simplification of trigonometric expressions
I would like to simplify this following trigonometric expression :
Code:
eq_liaison:= x0(t)-sin(alpha0(t))*sin(gamma0(t))*sin(beta0(t))*xb[1]+sin(alpha0(t))*sin(beta0(t))*cos(gamma0(t))*zb[1]+sin(alpha0(t))*cos(beta0(t))*yb[1]+cos(alpha0(t))*sin(gamma0(t))*zb[1]+cos(alpha0(t))*cos(gamma0(t))*xb[1]+l2[1]*(sin(psi[1](t))*sin(alpha0(t))*sin(gamma0(t))*sin(beta0(t))-cos(psi[1](t))*sin(alpha0(t))*sin(beta0(t))*cos(gamma0(t))-sin(psi[1](t))*cos(alpha0(t))*cos(gamma0(t))-cos(psi[1](t))*cos(alpha0(t))*sin(gamma0(t)))+l3[1]*(sin(theta[1](t))*sin(psi[1](t))*sin(alpha0(t))*sin(beta0(t))*cos(gamma0(t))+sin(theta[1](t))*cos(psi[1](t))*sin(alpha0(t))*sin(gamma0(t))*sin(beta0(t))+cos(theta[1](t))*sin(psi[1](t))*sin(alpha0(t))*sin(gamma0(t))*sin(beta0(t))-cos(theta[1](t))*cos(psi[1](t))*sin(alpha0(t))*sin(beta0(t))*cos(gamma0(t))+sin(theta[1](t))*sin(psi[1](t))*cos(alpha0(t))*sin(gamma0(t))-sin(theta[1](t))*cos(psi[1](t))*cos(alpha0(t))*cos(gamma0(t))-cos(theta[1](t))*sin(psi[1](t))*cos(alpha0(t))*cos(gamma0(t))-cos(theta[1](t))*cos(psi[1](t))*cos(alpha0(t))*sin(gamma0(t)))-xp[1](t) = 0
I would like to make groups like : cos(a)cos(b) - sin(a)sin(b)=cos(a+b)  but keepind the maximum of expression products
On the following example (2 equations below), the function combine(expr,trig) works well
Code:
eq_liaison[1] := cos(gamma(t))*r+(cos(gamma(t))*cos(psi(t))-sin(gamma(t))*sin(psi(t)))*l-x(t) = 0
eq_liaison[2] := sin(gamma(t))*r+(sin(gamma(t))*cos(psi(t))+cos(gamma(t))*sin(psi(t)))*l = 0
But, I would like maple do only the first simplifications in order to the maximum of expression products. The function combine(expr,trig) goes too far in the first equation and I obtain only expression sums.
Do you have ideas to simplify the first trigonometric equations
- with groups like : cos(a)cos(b) - sin(a)sin(b)=cos(a+b)
- and keeping products of expressions ?
Thank you for your help
