Question: Assigning package to command
In my code, I need to use 2 packages :
- with(LinearAlgebra)
- with(ListTools)
Problem :
It seems that the package with(ListTools) creates some troubles/ conflicts when I use some functions of the LinearAlgebra package such as DotProduct.
Here a small example to illustrate my issue
with(LinearAlgebra):
with(Student[MultivariateCalculus]):
with(plots):
with(MathML):
DotProduct(<0,0,l>, <0,0,l>, conjugate = false);
--> This code works
with(plots):
with(MathML):
with(ListTools):
--> This code doesn't work
I try to replace the line with the DotProduct by the following line but it still doesn't work
with(LinearAlgebra):-DotProduct(<0,0,l>, <0,0,l>, conjugate = false));
How can I do to use in my code both packages (LinearAlgebra and ListTools) ?
Thanks a lot for your help
