Question: How to get reverse probability?
When defining a plain standard distributed stochastic variable X, and can find the probability of X <= 0.6 using the Probability function, but how can I get the value for a certain probability, as is done with the fsolve function for example below.
However, the fsolve used to defined Prev above appears to be a bad way to do it, since the Prev function can't for example plot.
Is there some build in way of doing reverse of Probability for a stocastical variable ?
