Question: SurfaceInt VectorCalc and plots
Hi.
This is probably not very much maple related question, but to some extend it is.
After failing this question on my exam I have tried to solve it, but it seems like I cant get it right.
Given a sphere z^2+r^2=4 and a cylinder r=1 I was told to set up the volume integral for the element T enclose byt the outer sphere and the inner circle.
I tried to generate a plot but my skills are rather poor in plotting, if I could get the plot right I would be able to set up the volume integral. I have also tried to figure out how to do the surface integral and chose to use a task template as it is a bit more convinient when you find the syntax hard.
I would say I am familiar with the VectorCalculus:-SurfaceInt in cartesian for when i have intersection of two surfaces given in terms of z=
but this kind of problem is new to me.
Surface Integration over a Surface Defined Parametrically
Formulate and evaluate the surface integral of f(x, y, z) over a surface defined parametrically.
Surface Integral on a Surface Defined Parametrically
  Integrand
"f(x,y,z)="
   " x(u,v)="
"y(u,v)="
   " z(u,v)="
`≡`(F(u, v), f(x(u, v), y(u, v), z(u, v)))
`≡`(LinearAlgebra[Norm](N), sqrt((`∂`(y, z)/`∂`(u, v))^2+(`∂`(z, x)/`∂`(u, v))^2+(`∂`(x, y)/`∂`(u, v))^2))
"∫(∫)[S]f ⅆsigma =(∫)[u=a]^(u=b)(∫)[v=g(u)]^(v=h(u))F(u,v)||N|| ⅆv ⅆu"
"b="
"∫(∫)[S]f ⅆsigma=""(∫)[v=a]^(v=b)(∫)[u=G(v)]^(u=H(v))F(u,v)||N|| ⅆu ⅆv"
"a="
NULLNULL
with(plots):
p1 := plot3d([2*cos(u)*sin(v), 2*sin(u)*sin(v), 2*cos(v)], u = 0 .. 2*Pi, v = 0 .. Pi, color = green, transparency = .55):
p2 := plot3d([cos(u), sin(u), z], u = 0 .. 2*Pi, z = -2 .. 2, color = red, filled = true):
display(p1, p2)
p3 := plots:-sphereplot(2, theta = 0 .. 2*Pi, phi = 0 .. Pi, color = green, transparency = .55):
p4 := plots:-cylinderplot(1, theta = 0 .. 2*Pi, z = -2 .. 2, color = red):
plots:-display(p1, p2)
Download surface_int.mw
