Question: subs based on a variable
I'm trying to use subs to substitute an unknown variable with a number in a Matrix
My Matrix is called values and I have the following
change := f2:
subs(change = 5, values):
This does nothing but when I have the following, it works as expected (All f2 in the Matrix values are replaced with 5)
subs(f2,values):
I'm wondering if its trying to find and replace 'change'. If this is the case how can I get it to use whats assigned to the variable. (I've tried eval(change) but that doesn't work either)
Many thanks
