Question: How do I produce a sequence defined by a linear recurrence?
In Mathematica, there is a command "LinearRecurrence" that lists a sequence generated by a linear recurrence.
For example,
LinearRecurrence[{-3, 1}, {7, 2}, 10]
will produce the first ten numbers in the sequence defined by a0=7, a1=2; a_n = -3 an-1 + an-2.
Is there anything similar in Maple?
If not, what would be the easiest way to do the same?
UPDATE: Two answers show how to do this example with rsolve, but it seems that this solution does not help in general for recurrence of high order.
Thank you.
