Question: can Maple find solution to eigenvalue boundary value ODE directly?
newbie here. When I give Maple 2016.2  a boundary value ODE with an eigenvalue in it, it returns the trivial solution. I was wondering if Maple supports finding non-trivial solution and also give the eigenvalue values associated with the non-trivial solution?
ode:=diff(y(x),x$2)+lambda*y(x)=0;
bc:=y(0)=0,y(L)=0:
assume(L>0,L,'real'):
sol:=dsolve({ode,bc},y(x));
The outtput is `y(x)=0`
In Mathematica, it gives both trivial and non-trivial solution:
Clear[L0, lam, x, y, r]
ode = y''[x] + lam y[x] == 0;
bc = {y[0] == 0, y[L0] == 0};
sol = Assuming[Element[L0, Reals] && L0 > 0,
  DSolveValue[{ode, bc}, y[x], x]]
And the answer is
If Maple does not currently support this, any one knows if this will added to Maple 2017?
