Question: help with random numbers in sequence
I am trying to construct a random set of angles measured in degrees with pairs that are the equivalent in radians.  for example [0,0],[90,Pi/2],[-30,-Pi/6],etc...  but completely random.
so far I have the following:
randomize();
a := rand(-90 .. 90);
seq([a(i), convert(a(i)*degrees, radians)], i = 1 .. 4);
the trouble is it appars it is randomizing a both times it is called in the sequence.  I would like to have it randomize for each iteration in the sequence.
thanks in advance.
