Question: how to use showsource() command?
I can't figure how to use the showsource() command. There are no examples given.
kernelopts(version);
Maple 2017.0, X86 64 WINDOWS, May 17 2017, Build ID 1231047
If I use it on a local proc() it gives an error. Since it needs a file name
f := proc(x) if x <= 2 then print(x); print(x^2) end if; print(-x); x^3 end proc:
showsource(f);
Error, (in fopen) file or directory does not exist
From help:
The showsource command is similar to showstat, but displays the original
source code corresponding to the requested statements, if that source
code is available and, in the case of procedures retrieved from
libraries, kernelopts(keepdebuginfo) is true. If source code is
not available, showsource raises a warning and then produces
the same output as showstat.
But there is not one single example of how to use this command. I tried it on a local file (.mpl) in the same folder, but it complained.
currentdirName :="C:\\bla\\bla";
currentdir(currentdirName);
showsource("maple_proc.mpl");
Error, invalid input: showsource expects its 1st argument, p,
to be of type {`::`, name}, but received maple_proc.mpl
If I try
showsource(int);
Warning, no source information available; using showstat instead
Just looking for an example on how to use this command. (why help does not show an example?)
