Question: computation geometry
Hi
Is there any idea using Maple  to compute the leg lengths  in Stewart-Gough platform ( see the following figure)
I would like to make a code using cross-product and the unit Normal N
·       P is of length 13 and displaced in the Y direction by 10 degrees from the vertical (Z axis)
·       N is displaced in the X direction by 18 degrees from the vertical (Z axis)
·       LB is position [7 5] from the bottom plate centre in the XY plane
·       LT is in position [3.5 4.2] from the top-plate centre in the AB plane
Many thanks for any help
