Question: Command "Generate" produces the same objects each time
I need to create randomly several {1,2,3}-sequences of length 15. I execute:
> with(RandomTools):
> w:=Generate(list(posint(range = 3), 15)):
The problem is that when I close the program and then open and run it again, it always produces the same sequences.
What should I do in order to make it work really randomly? That is, to start at a "random" sequence as well?
Thanks!
