Question: OpenMaple encoder problem
Hi everyone,
I have to make a project that need to use openmaple in java. The problems is when i get the output data of the textCallBack method, i try to convert the output to utf-8 format using the UTF8Encoder provided in java Maple JAR file in order to display Vietnamese language but it doesn't work (the output type is String). Are there any solutions? Thank you.
