Question: Solving a set of equations: want to get numeric floating values
I wish to solve three linear simultaneous equations and obtain the solutions in floating point form.
the following works...
solvec:=fsolve({T+N1-m1=0, N2-N1-m2=0,T-N2-m3=0}, {T,N1,N2});
...but the solutions are given in either symbolic, or equation form.  I would like numbers - floating point form.
Below is my attempt to solve this.  with(plots) & with(plottools) is not necessary for this - but I was doing some related graphic work.  I did try with(RealDomain), but it seemedto make little difference.  I have done a copy & paste of an rtf file, but the Maple output has not come out so well.  Any help would be appreciated.
> restart:
with(plots):
with(plottools):
with(RealDomain);
#Masses in kg (or pounds!)
m1:=70.0:m2:=25.0:m3:=3.0:
#Equations
#Above gives the solutions in symbolic or equation form, as well as putting the solutions in a set.  How can the programme distinguish between the various values?
# From here is my attempt to form floating point values – to no avail.
NTab:=convert([solvec],table);
N1A:=evalf(solvefor[N1](T+N1-m1*g=0, N2-N1-m2*g=0,T-N2-m3*g=0));
N1B:=convert(N1A, float);
#Problem to isolate the solutions in the vector in floating form,
#and also get the correct ones.  NB the solution is a set - not an ordered list.
maxvec:=max(solvec[1],solvec[2],solvec[3]);
#maxvec:=convert(max(solvec[1],solvec[2],solvec[3]), float);
maxvec:=convert(solvec[2], float);
solvec[2];
whattype(solvec[2]);
type(N2,symbol);
type(solvec[2],equation);
N2_fl:=evalf(solvec[2]);
N2_fl:=convert(solvec[2], float);
N3:=N2_fl+3;
#Actual true answers
#T:=(m1+m2+m3)/2;
#N1:=(m1-m2-m3)/2;
#N2:=T-m2;
OUTPUT:
Error, (in simpl/max) arguments must be of type algebraic
Error, (in simpl/relopsum) invalid terms in sum
