Question: Maple 2017 - Plotting with Units
Hi.
From what I can tell this is a common problem that comes up on the forums once and a while where most response provide answers that don't hit the core of the problem.  That being, when using the plot function in maple how do we properly have it plot a function that contains units within it.  This is an important feature for anyone who works with problems where unit tracking and conversion must be checked, yet the problem complexity becomes large enough such that this isn't feasible to do by hand.
To give a brief example:
T := (.2*11600)*Unit('K');
n__0 := 10^12*Unit(1/'m'^3);
Q := 0.865e-11*Unit('C');
lambda__D := sqrt(epsilon__0*k__B*T/(n__0*q__e^2));
              lambda__D := 0.003326865078 Unit(m)
Phi__F := proc (r) options operator, arrow; (1/4)*Q/(Pi*epsilon__0*r) end proc;
Phi__P := proc (r) options operator, arrow; Phi__F(r)*exp(-r/lambda__D) end proc;
Now lets say I want to plot the Phi functions this would require a plot function with a range that is in the units of meters.  But if I enter the statement:
plot(Phi__F(r), r = 0.1e-1*lambda__D .. 4*lambda__D)
I will produce a plot with the incorrect units on the y-axis, even though lambda__D is in units of meter, likewise the same thing will occur if I try to append the meter unit to the range manually.
plot(Phi__F(r), r = 0.1e-1*lambda__D*Unit('m') .. 4*lambda__D*Unit('m'))
Now, we can make progress if we define the unit of r within the function definition itself.
plot(Phi__F(r*Unit('m')), r = 0.1e-1*lambda__D .. 4*lambda__D)
So "Yay!", right?  Where as I have mixed feelings on that since a range shouldn't require unit additions in the function itself this is at least functional.  The second part of this problem occurs when you try to plot two functions at once, say both Phi__F and Phi__P as follows
plot({Phi__F(r*Unit('m')), Phi__P(r*Unit('m'))}, r = 0.1e-1*lambda__D .. 4*lambda__D);
Warning, expecting only range variable r in expression .7777911056e-1/r*Units:-Unit(V) to be plotted but found name V
Now we recieve a warning message and an empty plot.  For some reason maple things that V is a variable, not a unit.  What the hell?  I would like a little help here as the online docs are useless.
-- Matt
P.S.  If you'd like to know more about the example problem it happens to deal with the debye length of a plasma.
