Question: subs fails to for one variable
``Can anyone explain why 'subs' will sbstitute 'a' and 'c' but not 'b' (equations 2.3 and 2.4) in the attached document.
``I have tried everything I can think of but nothing works.
If I cut and paste 2.3 and 2.4 to a clean document it works.  I tried coying the whole document t a clean sheet but that does not fix the problem.
NULLNULL
Va := sqrt(2)*Vrms*sin(theta)Vmax =  RmsMS phase to neutral voltage
Vb := sqrt(2)*Vrms*sin(theta-2*Pi*(1/3))
Vc := sqrt(2)*Vrms*sin(theta+2*Pi*(1/3))
Vab := Va-Vb
Vbc := Vb-Vc
Vca := Vc-Va
com1 := rhs(simplify(solve({Vc = Va, 0 < theta and theta < Pi}, theta, allsolutions))[1]) = (1/6)*PiNULL
com2 := rhs(simplify(solve({Vb = Vc, 0 < theta and theta < Pi}, theta, allsolutions))[1]) = (1/2)*PiNULL
com3 := rhs(simplify(solve({Va = Vb, 0 < theta and theta < Pi}, theta, allsolutions))[1]) = (5/6)*PiNULL
com4 := rhs(simplify(solve({Va = Vc, Pi < theta and theta < 2*Pi}, theta, allsolutions))[1]) = (7/6)*Pi
com5 := rhs(simplify(solve({Vb = Vc, Pi < theta and theta < 2*Pi}, theta, allsolutions))[1]) = (3/2)*Pi
com6 := rhs(simplify(solve({Va = Vb, Pi < theta and theta < 2*Pi}, theta, allsolutions))[1]) = (11/6)*PiNULL
NULL  NULL
NULL``
plot(subs(Vrms = 100, [Va, Vb, Vc, Vab, Vbc, Vca]), theta = 0 .. 3*Pi)
The  #1 diode is forward biased and switches on when Va>Vc (Va=Vc). The voltage VD will be equal to Va-Vb until diode #2 turns on when Vc< Vb. Then VD will equal Vc-Vc.
The switching angle for the diodes is given above. If phase control is used all commutation is delayed by the angle α.
NULL``
Without phase delay the average (DC) voltage applied to the laod is the average value of the 6 commutation periods over one cycle:
Van := sqrt(2)*Erms*sin(theta)Emax =  RmsMS phase to neutral voltage
Vbn := sqrt(2)*Erms*sin(theta-2*Pi*(1/3))
Vcn := sqrt(2)*Erms*sin(theta+2*Pi*(1/3))
Eq1 := Vdo = 6*(int(Van-Vbn, theta = com1 .. com2))/(2*Pi)
Vdo = 3*3^(1/2)*2^(1/2)*Erms/Pi
Eq2 := Vdc = 6*(int(Van-Vbn, theta = com1+alpha .. com2+alpha))/(2*Pi)
Vdc = 3*2^(1/2)*Erms*3^(1/2)*cos(alpha)/Pi
Commutation
The switching between diodes can not occur instantaneously because the supply circuit is inductive. Current can not change instantaneously in and inductive circuit.
The transfer of load current from the out-going phase to the incomming phase is accomplshed by a period of symultaneous conduction of the two adjacent diodes the creation of a circulating current between these two phases that resembles short circuit between the two phases.
The circulating current produces equal voltage drop with opposid polarities in each phase. In the out-going phase the drop adds to the soruce voltage and in the incomming phase the drop subtracts from the source voltage. Only the drop in the incomming phase effects the DC output voltage.
During commutation intervil com1 to com2 phases a and c are shorted while Id is transfered from phase c to phase a. During this time voltage Va-Vb minus the voltage drop in a phase caused by the commutation. This voltage drop is 1/2 the Vac voltage.
`&Delta;e` := 1/2*(Van-Vcn)
(1/2)*2^(1/2)*Erms*sin(theta)-(1/2)*2^(1/2)*Erms*cos(theta+(1/6)*Pi)
and      Va=Vc at π/6
`&Delta;E__Avg` = 6*(int(`&Delta;e`, theta = (1/6)*Pi+alpha .. (1/6)*Pi+alpha+mu))/(2*Pi)
`&Delta;E__Avg` = 3*((1/2)*2^(1/2)*Erms*cos((1/6)*Pi+alpha)+(1/2)*2^(1/2)*Erms*sin((1/3)*Pi+alpha)-(1/2)*2^(1/2)*Erms*sin((1/3)*Pi+alpha+mu)-(1/2)*2^(1/2)*Erms*cos((1/6)*Pi+alpha+mu))/Pi
`&Delta;E__Avg` = (3/2)*Erms*2^(1/2)*(cos((1/6)*Pi+alpha)+sin((1/3)*Pi+alpha)-sin((1/3)*Pi+alpha+mu)-cos((1/6)*Pi+alpha+mu))/Pi
`&Delta;E__Avg` = (3/2)*2^(1/2)*Erms*3^(1/2)*cos(alpha)/Pi-(3/2)*Erms*2^(1/2)*3^(1/2)*cos(alpha)*cos(mu)/Pi+(3/2)*Erms*2^(1/2)*3^(1/2)*sin(alpha)*sin(mu)/Pi
`&Delta;E__Avg` = (3/2)*Erms*2^(1/2)*3^(1/2)*((-cos(mu)+1)*cos(alpha)+sin(alpha)*sin(mu))/Pi
combine(`&Delta;E__Avg` = (3/2)*Erms*2^(1/2)*3^(1/2)*((-cos(mu)+1)*cos(alpha)+sin(alpha)*sin(mu))/Pi, trig)
`&Delta;E__Avg` = (1/2)*(-3*3^(1/2)*2^(1/2)*Erms*cos(alpha+mu)+3*2^(1/2)*Erms*3^(1/2)*cos(alpha))/Pi
`&Delta;E__Avg` = -(3/2)*3^(1/2)*2^(1/2)*Erms*(cos(alpha+mu)-cos(alpha))/Pi
DC output voltage
V__D = Vdc-`&Delta;E__Avg`
subs([Vdc = 3*2^(1/2)*Erms*3^(1/2)*cos(alpha)/Pi, `&Delta;E__Avg` = -(3/2)*3^(1/2)*2^(1/2)*Erms*(cos(alpha+mu)-cos(alpha))/Pi], V__D = Vdc-`&Delta;E__Avg`)
V__D = 3*2^(1/2)*Erms*3^(1/2)*cos(alpha)/Pi+(3/2)*3^(1/2)*2^(1/2)*Erms*(cos(alpha+mu)-cos(alpha))/Pi
V__D = (3/2)*3^(1/2)*2^(1/2)*Erms*(cos(alpha)+cos(alpha+mu))/Pi
Equating the intigral of the voltage drop between the phase A and C  to the intigral of the voltage rise across the two phase inductances (thes intigrals represent eqivalent flux).
int(Van-Vcn, theta = (1/6)*Pi+alpha .. (1/6)*Pi+alpha+mu) = int(2*L*omega, theta = 0 .. Id)
2^(1/2)*Erms*cos((1/6)*Pi+alpha)+2^(1/2)*Erms*sin((1/3)*Pi+alpha)-2^(1/2)*Erms*cos((1/6)*Pi+alpha+mu)-2^(1/2)*Erms*sin((1/3)*Pi+alpha+mu) = 2*L*omega*Id
2^(1/2)*Erms*3^(1/2)*cos(alpha)-Erms*2^(1/2)*3^(1/2)*cos(alpha)*cos(mu)+Erms*2^(1/2)*3^(1/2)*sin(alpha)*sin(mu) = 2*L*omega*Id
(14)
-Erms*3^(1/2)*2^(1/2)*((cos(mu)-1)*cos(alpha)-sin(alpha)*sin(mu)) = 2*L*omega*Id
(15)
combine(-Erms*3^(1/2)*2^(1/2)*((cos(mu)-1)*cos(alpha)-sin(alpha)*sin(mu)) = 2*L*omega*Id, trig)
-3^(1/2)*2^(1/2)*Erms*cos(alpha+mu)+2^(1/2)*Erms*3^(1/2)*cos(alpha) = 2*L*omega*Id
(16)
cos(alpha+mu) = -(1/6)*(2*L*omega*Id-2^(1/2)*Erms*3^(1/2)*cos(alpha))*3^(1/2)*2^(1/2)/Erms
(17)
cos(alpha+mu) = -(1/3)*3^(1/2)*2^(1/2)*L*omega*Id/Erms+cos(alpha)
(18)
NULL``
subs(cos(alpha+mu) = -(1/6)*(2*L*omega*Id-2^(1/2)*Erms*3^(1/2)*cos(alpha))*3^(1/2)*2^(1/2)/Erms, V__D = (3/2)*3^(1/2)*2^(1/2)*Erms*(cos(alpha)+cos(alpha+mu))/Pi)
V__D = (3/2)*3^(1/2)*2^(1/2)*Erms*(cos(alpha)-(1/6)*(2*L*omega*Id-2^(1/2)*Erms*3^(1/2)*cos(alpha))*3^(1/2)*2^(1/2)/Erms)/Pi
(19)
V__D = 3*2^(1/2)*Erms*3^(1/2)*cos(alpha)/Pi-3*L*omega*Id/Pi
(20)
Line Currents
A phase current intervals
RMS Current Line
Using*A*Phase*current
(2.1)
I__RMS = sqrt(A/Pi)
I__RMS = (A/Pi)^(1/2)
(2.2)
A = rhs(A1 = -(3/16)*Erms^2*((-8*cos(mu)*sin(mu)-8*mu+16*sin(mu))*cos(alpha)^2-8*sin(alpha)*(cos(mu)-1)^2*cos(alpha)+4*cos(mu)*sin(mu)-4*mu)/(L^2*omega^2))+rhs(A2 = Idc^2*((2/3)*Pi-mu))+rhs(A3 = (1/4)*(6*(cos(mu)*sin(mu)-2*sin(mu)+mu)*cos(alpha)^2+6*sin(alpha)*(cos(mu)-1)^2*cos(alpha)-3*cos(mu)*sin(mu)+3*mu)*Erms^2/(L^2*omega^2)+Idc*((sin(mu)-mu)*cos(alpha)+sin(alpha)*(cos(mu)-1))*3^(1/2)*2^(1/2)*Erms/(L*omega)+Idc^2*mu)
A = -(3/16)*Erms^2*((-8*cos(mu)*sin(mu)-8*mu+16*sin(mu))*cos(alpha)^2-8*sin(alpha)*(cos(mu)-1)^2*cos(alpha)+4*cos(mu)*sin(mu)-4*mu)/(L^2*omega^2)+Idc^2*((2/3)*Pi-mu)+(1/4)*(6*(cos(mu)*sin(mu)-2*sin(mu)+mu)*cos(alpha)^2+6*sin(alpha)*(cos(mu)-1)^2*cos(alpha)-3*cos(mu)*sin(mu)+3*mu)*Erms^2/(L^2*omega^2)+Idc*((sin(mu)-mu)*cos(alpha)+sin(alpha)*(cos(mu)-1))*3^(1/2)*2^(1/2)*Erms/(L*omega)+Idc^2*mu
(2.3)
subs((-8*cos(mu)*sin(mu)-8*mu+16*sin(mu))*cos(alpha)^2-8*sin(alpha)*(cos(mu)-1)^2*cos(alpha)+4*cos(mu)*sin(mu)-4*mu = a, (6*(cos(mu)*sin(mu)-2*sin(mu)+mu))*cos(alpha)^2+6*sin(alpha)*(cos(mu)-1)^2*cos(alpha)-3*cos(mu)*sin(mu)+3*mu = b, (sin(mu)-mu)*cos(alpha)+sin(alpha)*(cos(mu)-1) = c, A = -(3/16)*Erms^2*((-8*cos(mu)*sin(mu)-8*mu+16*sin(mu))*cos(alpha)^2-8*sin(alpha)*(cos(mu)-1)^2*cos(alpha)+4*cos(mu)*sin(mu)-4*mu)/(L^2*omega^2)+Idc^2*((2/3)*Pi-mu)+(1/4)*(6*(cos(mu)*sin(mu)-2*sin(mu)+mu)*cos(alpha)^2+6*sin(alpha)*(cos(mu)-1)^2*cos(alpha)-3*cos(mu)*sin(mu)+3*mu)*Erms^2/(L^2*omega^2)+Idc*((sin(mu)-mu)*cos(alpha)+sin(alpha)*(cos(mu)-1))*3^(1/2)*2^(1/2)*Erms/(L*omega)+Idc^2*mu)
A = -(3/16)*Erms^2*a/(L^2*omega^2)+Idc^2*((2/3)*Pi-mu)+(1/4)*(6*(cos(mu)*sin(mu)-2*sin(mu)+mu)*cos(alpha)^2+6*sin(alpha)*(cos(mu)-1)^2*cos(alpha)-3*cos(mu)*sin(mu)+3*mu)*Erms^2/(L^2*omega^2)+Idc*c*3^(1/2)*2^(1/2)*Erms/(L*omega)+Idc^2*mu
(2.4)
Download subs_failed.mw
