Question: Blank spaces in pathname
I used the folowing command, but the problem is that there is a blank space in the name of a directory.
!curl -m 3 -o /Users/John/Documents/P Admin/a.dat  --insecure https://www.google.com/?gws_rd=ssl;
I used macosx, and in a Terminal window the correct path must be written as :
/Users/John/Documents/P\ Admin/a.dat
But, impossible to set the right expression with Maple.
I used for instance:
!curl -m 3 -o /Users/John/Documents/P\\ Admin/a.dat  --insecure https://www.google.com/?gws_rd=ssl;
But it failed.
What is the right expression?
Best regards
