Question: pdsolve erratically returns null result
      I've run into a strange problem with pdsolve. I'm attempting to solve a small PDE system. It seems pdsolve is quite capable of handling it, as it will occasionally return a valid answer. However, equally often, it returns a NULL result. And this is without changing anything else in the code: consecutive runs randomly produce a valid or NULL result.
      The only possible explanation I have is that, since this is a part of a larger code (~2k lines), perhaps something is going on with memory management? This is being run on a server (24 cores, 50GB RAM), so the total memory usage never rises above 0.5%. The cpu usage does hover around 100%-105% of a single core, but I doubt that's a problem. I've tried increasing stacklimit, processlimit, and cacheclearlimit, but it didn't seem to help.
      So, my question is, what sort of debugging or testing can I try? Are there any standard "tricks" to use here?
Thanks!
